Odd routing problem with site to site vpn
All Forums >> [ISA 2006 Firewall] >> Branch Office >> Odd routing problem with site to site vpn Page: [1]
Odd routing problem with site to site vpn - 27.Oct.2007 6:59:33 PM
jsalow
I have 3 isa 2006 arrays- home office and two remote offices. On one of the remote offices I have a site to site vpn that is routing two ip address ranges 10.1.4.0-10.1.4.255 and 10.1.5.0-10.1.5.255. The odd thing is that for some reason it adds one static ip route - 10.1.4.0 with a different mask of 255.255.254.0. It totally ignores the 10.1.5.0 route. If I remove the 10.1.4.0 address range, it correctly adds 10.1.5.0 on 255.255.255.0. If I add the 10.1.4.0 range back, the 10.1.5 disappears again, and the 10.1.4 on 255.255.254.0 shows up. I have another remote office setup exactly the same routing addresses 10.1.6.0 and 10.1.5.0 address ranges - it correctly adds the static routes.
Any ideas? See attached pictures.
settings and routing from troubled branch
http://lakeforestweather.com/route1.jpg
http://lakeforestweather.com/route2.jpg
http://lakeforestweather.com/route3.jpg
settings and routing from branch that works
http://lakeforestweather.com/route4.jpg
http://lakeforestweather.com/route5.jpg
http://lakeforestweather.com/route6.jpg
(the static routes show up in the branch that works whether I add persistent routes or not. If I add persistent routes to the troubled branch, nothing routes)
RE: Odd routing problem with site to site vpn - 18.Dec.2007 4:00:20 PM
pwindell
Delete the Static Routes.  There is no purpose for there to even be any static routes in this case.  Everything is classified as a "directly connected network" in this situation which means that there are no Static Routes or even any Dynamic Routes.
Stay away from the RRAS Admin MMC.   ISA totally "owns" RRAS and anything you mess with in RRAS Admin has the potential to conflict with ISA. ISA will configure RRAS the way it wants it to be automatically.
The Routing Table entries are built automatically based on the Nic configuration.  Verify that the TCP/IP Config on all of the nics is correct,..pay particular attention to the masks,...if they are correct the routing table will be correct.
Sometimes the best thing to do is clear the table and reboot. The table will rebuild on reboot.  You can clear the table with the command "route /f" from a command prompt.
Phillip Windell
www.wandtv.com
(in reply to jsalow)
