Once again on 0xc0040017 FWX_E_TCP_NOT_SYN_PACKET_DROPPED
All Forums >> [ISA 2006 General] >> Installation and Planning >> Once again on 0xc0040017 FWX_E_TCP_NOT_SYN_PACKET_DROPPED Page: [1]
Once again on 0xc0040017 FWX_E_TCP_NOT_SYN_PACKET_DROPPED - 17.Jun.2008 9:33:05 AM
author22
Hi! As far as I can understand this error means that a TCP session was closed (from ISA's point of view) before the reply was received. So the reply is not treated as a reply but as a separate connection attempt.
I have a strange case of this error. I have two ISA EE arrays which are Front-End and Back-End. CSS is located in the internal network. So all the communications between CSS and Front-End array members go through the Back-End firewall. My DMZ uses private IPs so I use route relationship between Internal network and DMZ and NAT relationship between DMZ and External network. Everything worked fine until this week.
Sorry I can't get which of the last changes has broken it. But now the communication between my Internal network and Front-End array members doesn't work. I can ping the Front-Ens from Internal network and vice versa. I can also see that my management PCs try to connet to the Front-Ends using RPC and 'MS Firewall Control' protocols. But I still cannot manage my Front-End servers in ISA MMC. On 'Servers' node of the MMC my Front-Ends are displayed with red Error sign and I constantly get a message in the upper part of the MMC sayint that it is 'Unable to retrieve data from' the Fotnt-ends.
I think that the problem is that Front-Ends cannot properly reply to the connection attempts from my Managemnt PCs. I see these reply attempts as regular connection attempts from the Front-Ends to the management PCs. And these attempts fail with status 0xc0040017 FWX_E_TCP_NOT_SYN_PACKET_DROPPED.
RE: Once again on 0xc0040017 FWX_E_TCP_NOT_SYN_PACKET_D... - 26.Jun.2008 12:24:09 PM
Are there rules in place to support the connection? Check your System Policy to make sure.
(in reply to author22)
RE: Once again on 0xc0040017 FWX_E_TCP_NOT_SYN_PACKET_D... - 8.Jul.2008 6:37:01 AM
author22
Sorry Tom, sorry all the forum visitors. I straggled this problem for about a month. And today during SP1 application I found I was using the wrong credentials for my front-end servers.
So this was the cause why they were unavailable in ISA MMC. I do still see some rare "0xc0040017 FWX_E_TCP_NOT_SYN_PACKET_DROPPED" events but that's not a big problem any more.
RE: Once again on 0xc0040017 FWX_E_TCP_NOT_SYN_PACKET_D... - 11.Jul.2008 11:44:22 AM
Ah, OK!
Good to hear you got things working and thanks for the follow up!
