Opening Web site problem
Opening Web site problem - 23.Dec.2007 12:21:14 PM
osama_seddik
Hello All, i have this problem, when i try to connect to this site http://mmsfestival.etisalat.com.eg behind the ISA server 2004 (using only secure Nat) i can't open the web site , while i can open it outside the ISA server 2004 connection(using the Router IP directly) , i noticed that the only way to open the site behind the ISA is to use the web proxy , so could u please help me to find any solution to open this site without using the web proxy. thanks in advance Osama
RE: Opening Web site problem - 23.Dec.2007 3:37:17 PM
Rotorblade
Hi, Using only SecureNAT you will need an "All users" access rule to allow. SecureNAT client does not support authentication and sounds as if you have "require authentication" on the web proxy (which is not recommended) or through an access rule. Best option is to create a specific destination set for the problem site and apply to an access rule that does not require authentication. HTH RB
RE: Opening Web site problem - 23.Dec.2007 4:41:50 PM
osama_seddik
hello Rotorblade , first of all i'd like to thank you for your quick reply, i did what u wrote but unfortunately the same problem ocured. Regards, Osama
RE: Opening Web site problem - 25.Dec.2007 6:53:02 AM
faridabz
a have a problem with the same site, my problem is ( with the proxy settings in the IE i can't access the site, but if i remove it from the settings no problem ), how can i solve this problem. thanks for your time!!!!!!
