Oracle and DMZ
All Forums >> [ISA Server 2000 Firewall] >> DMZ >> Oracle and DMZ Page: [1]
Oracle and DMZ - 27.Dec.2003 8:35:00 PM
rglauser
I need to access an Oracle application through a DMZ. I have set up my ISA server and written persistent routing statements to point internal users through the DMZ to the Oracle server. I have written protocol definitions for 1521 inbound with 1024-65535 as secondary connections. I can reach the Oracle server and access and write data. Where it falls apart is when I attempt to download information to the local database on the user's machine. I can't find anything in the firewall logs to suggest a port that is not opening. I get a very specific TNS Listener error that suggests that it might be a programing error on their part but I have been unable to reach the authors of this piece of software to see if this is the case. My first question is: Does ISA treat a DMZ interface that is not trusted as an external interface, thus allowing secondary connections, or should I be looking at writing protocol definitions to open each likely port?
RE: Oracle and DMZ - 29.Dec.2003 4:43:00 PM
Hi R,
The DMZ interface is only exposed to packet filters and should not be included in the LAT.
(in reply to rglauser)
RE: Oracle and DMZ - 29.Dec.2003 6:00:00 PM
rglauser
It is not part of the LAT. If you look at DMZ and Spoofing posted on Dec. 18, 2003 you will see my current configuration.
RE: Oracle and DMZ - 3.Jan.2004 8:06:00 PM
khowlette
you may need 1526 as well. I did it internal LAN to DMZ and needed to specify secondary ports 1025-65536. Also check tnsnames is resloving, you may need to edit tnsnames.ora file.
check out this link as well http://www.winnetmag.com/Windows/Article/ArticleID/24863/24863.html
RE: Oracle and DMZ - 8.Jul.2005 6:02:00 PM
sergiovc
I used the Microsoft Management Console (MMC) ISA Management snap-in to create a protocol definition named SQL*Net (Inbound) with the following parameters.
Port number: 1521
Protocol type: TCP
Direction: Inbound
No secondary connections
Then, I created a client address set that included the clients on the DMZ. I also created a publishing rule for the Oracle server. I applied the publishing rule to the SQL*Net (Inbound) protocol and to requests from the client set.
On the Oracle server, I added the system environment variable setting USE_SHARED_SOCKET, with the value TRUE. On Oracle for Windows, you can alternatively add a registry value called USE_SHARED_SOCKET to create the setting. This environment variable setting works on Windows and UNIX platforms.
I used Oracle's Net8 Easy Config utility to configure clients to point to the ISA Server's external interface. Then, I used Notepad to edit the connection string in C:\orawinnt\net80\admin\tnsnames.ora. I added the text (SERVER=DEDICATED) immediately after the text (SID=DB) in the connection string. UNIX requires the same change in the tnsnames.ora file. After my changes, the client connection from the DMZ to Oracle was successful.
