PROBLEM: Domain Blocking with Squid Blacklist
All Forums >> [ISA Server 2004 Firewall] >> HTTP Filtering >> PROBLEM: Domain Blocking with Squid Blacklist Page: [1]
PROBLEM: Domain Blocking with Squid Blacklist - 15.Sep.2006 12:06:03 PM
Aspro
Hi everybody,
I have imported un blacklist from Squid on my ISA Server.
I've discovered that the ISA doesn't use Domain Filtering.
For exemple, I have a domain with "groingroin.com" and when I type the url www.groingroin.com the rule is not considered.
The rules I've created are:
first one: Deny all protocols from Internal to "list of domain" for Everyone
Second one: Allow http from Internal to Internal for everyone (I'm in a single NIC configuration, so I don't have the "External" choice)
Do you have any ideas?
Thank's for your help!!!
< Message edited by Aspro -- 15.Sep.2006 12:46:35 PM >
RE: PROBLEM: Domain Blocking with Squid Blacklist - 12.Oct.2006 8:21:35 AM
yome86
Hello,
I had the same problem before and it is because ISA need to have in his Domain sets *domain.com and not just domain.com to work.
On my side, to solve this problem I have modified the importing script to add a *  at the start of each line. This solution is working but generate some problems because for example for the IP addresses in the blacklist like 22.22.22.22, in the ISA you will have *22.22.22.22 so all the sites like 122.22.22.22 will be blocked.
So if somebody has a better solution...
Hope this will help.
Guillaume
(in reply to Aspro)
