Pls. Help:- SSL Connection
All Forums >> [ISA Server 2004 General ] >> Web Publishing >> Pls. Help:- SSL Connection Page: [1]
Pls. Help:- SSL Connection - 14.Mar.2004 10:06:00 AM
pal_tej
Greetings!
Dear All,
I am using ISA on a win2k server. I need to allow my internal users to access one website. In which they need to login using SSL.
I have allowed Telnet 992 port outbound which the client has instructed. I have enabled the SSL Filters in outgoing web requests, incoming web requests.
Even I have entered the SSL ports 443 in routing port registeries.
Now only one of my internal user is able to connect to my cleints website. If second user is trying, they always get this error.
"HTTP/1.1 502 Proxy Error (The specified Secure Sockets Layer (SSL) port is not allowed. ISA Server is not configured to allow SSL requests from this port. Most Web browsers use port 443 for SSL requests."
Pls. do the needful as it is required to retain my Job.
Tej
"[Smile]"
RE: Pls. Help:- SSL Connection - 15.Mar.2004 4:15:00 PM
Hi Tej,
Why are you enabling telnet ports?
You probably need to add to the tunnel port range. Check out:
http://support.microsoft.com/default.aspx?scid=kb;en-us;283284
(in reply to pal_tej)
RE: Pls. Help:- SSL Connection - 19.Mar.2004 5:02:00 AM
pal_tej
Dear Tom,
I have already done this suggested solution. Still the problem is there. Only one user is able to connect.
If I put this external ip on my router and use it as gateway, everybody can connect.
I am in a big trouble what to do. Pls. help.
regards,
tejpal
RE: Pls. Help:- SSL Connection - 20.Mar.2004 8:13:00 PM
Hi Tej,
I have a script now. Send me an email at tshinder@isaserver.org and I'll send it to you.
