Pls Help : Unable to register a remote SQL server
Pls Help : Unable to register a remote SQL server - 6.Apr.2006 1:23:53 PM
kaliste
Hi, Config ------------------------------------------- Win 2k3 sp1 / ISA 2000 sp2 Problem ------------------------------------------- I have been unable to connect/register to our remote SQL servers on our web hosts but have been able to connect to the same remote sql servers via a notebook from home (dial-up). Since the problem exists only when we try to connect while at office it seems the problem lies with the ISA configurations Also we are able to connect /register to SQL servers of our clients via vpn. Solutions Attempted so far ------------------------------------------- - Create protocol rule for 1433
// kbid=299673 // URL (http://support.microsoft.com/?kbid=299673) prior to this we used to get an error sql server does exist / denied, after implementation of this solution, we have ended with the following "General network error ... check your network documentation. ConnectionOpen(PreLoginHandshake())" a more verbose error from odbcping -s server.ip COULD NOT CONNECT TO SQL SERVER SQLState: 08001 Native Error: 11 Info. Message: [Microsoft][ODBC SQL Server Driver][DBNETLIB]General network error. Check your network documentation. SQLState: 01000 Native Error: 10060 Info. Message: [Microsoft][ODBC SQL Server Driver][DBNETLIB]ConnectionOpen (PreLoginHandshake()). note: an alternative to the above opened 1433 / 1434 in both directions that did not help as well.. problem repeated itself as mentioned above - Implemented the RPC filter solutions
KBid : 887222 // URL (http://support.microsoft.com/?id=887222) this did not work as well.... - Using "MinTickBeforePortReuse = 240000" // ref : stefan spousele article : "The Mystery of the failing POP3 Access with ISA 2000"
While reading through some db forums i happen to fall on some a link suggested it could be a winsock error (native error 10060 is documented: WSAETIMEDOUT 10060) url // (http://www.dbforums.com/printthread.php?t=484808)... so i googled up native error 10060 ended with the article of stefan spousele "The Mystery of the failing POP3 Access with ISA 2000 " since this was supposed to be for all TCP protocols... but this has not worked as well I hope somebody here can help me ... best regards kaliste
RE: Pls Help : Unable to register a remote SQL server - 8.Apr.2006 1:28:25 PM
Hi kaliste, first of all, check out http://msdn.microsoft.com/library/default.asp?url=/library/en-us/winsock/winsock/windows_sockets_error_codes_2.asp to understand what the winsock error codes mean. For the case WSAETIMEDOUT 10060 it means Connection timed out: A connection attempt failed because the connected party did not properly respond after a period of time, or the established connection failed because the connected host has failed to respond. Now, to find out where the problem is situated, I would first check out if you can reach the SQL server on TCP port 1433. Assuming that the SQL server is located external to the ISA server, I suggest that you test it from outside the ISA server with Jim's excellent WinsockTool (http://isatools.org/winsocktool.msi) or a simple telnet command (telnet IP-address 1433). In both cases the connection should succeed. Once you have verified that the SQL server is indeed reachable on TCP port 1433, you should test next from inside ISA server. Of course we assume here you that you have a protocol rule allowing the protocol TCP port 1433 Outbound and a site&content rule allowing access to the remote SQL server. If it still doesn't work, what is the ISA logging telling you? Just make sure that you have enabled the logging of all fields. HTH, Stefaan
RE: Pls Help : Unable to register a remote SQL server - 8.Apr.2006 6:26:22 PM
LLigetfa
I don't know squat about ISA 2000 but I do know that W2K3SP1 disables PMTUDiscovery and that causes packet size related issues with ISA 2K4.
RE: Pls Help : Unable to register a remote SQL server - 8.Apr.2006 6:42:13 PM
Hi kaliste, according to the posted log entries, it doesn't sound that ISA is blocking the connection. Do you have evidence that for a dial-up user the SQL server is accessed through TCP port 1433 and not through another protocol? If you like you can post the IP address of the SQL server (or send me the info in a private message) and I can test it out. BTW --- check out that you have implemented *all* Windows 2003 patches. If so, make sure that EnablePMTUDiscovery registry entry is also enabled. Check out http://support.microsoft.com/?kbid=905179 for more info. This is a Windows 2003 setting and therefore applies also to ISA 2000 server. HTH, Stefaan
