Port Forwarding / Redirection with ISA 2006?
Port Forwarding / Redirection with ISA 2006? - 28.Apr.2007 8:43:47 AM
CODES
Hi all- I was wondering how I could accomplish a standard port forwarding or port redirection for a standard service like RDP. Scenario: ISA Server 2006 shall redirect incoming requests for port 3380 to an internal IP address with port number 3389. I already tried this by setting up a firewall rule and changing the ports but neither could I establish a connection successfully nor was a log entry made. Any ideas, whitepapers, or help? Cheers, Holger
MCP, MCDST, MCSA, MCSE, MCT, VCP, SPS, STA, SCSE, TCSE
RE: Port Forwarding / Redirection with ISA 2006? - 28.Apr.2007 9:54:58 AM
Hi Holger, that's easily accomplished in ISA 2006. Start with a standard RDP Server server publishing rule. On the Traffic tab there is button Ports. There you can change the TCP ports used. HTH, Stefaan
RE: Port Forwarding / Redirection with ISA 2006? - 28.Apr.2007 11:28:46 AM
Hi Holger, is the published host configured as a SecureNAT client only? It should. Also, what is the ISA live logging telling you? HTH, Stefaan
RE: Port Forwarding / Redirection with ISA 2006? - 28.Apr.2007 12:18:51 PM
CODES
Hi Stefaan, yes that's right. The host (Win 2003) is configured to be just a "normal" client that accesses external resources over the ISA Server 2006. And the live log doesn't even show the attemted connection... If I replace the ISA with an "ordinary" packet filter port redirection works fine. Cheers, Holger
RE: Port Forwarding / Redirection with ISA 2006? - 28.Apr.2007 6:10:12 PM
Hi Holger, quote:
And the live log doesn't even show the attemted connection... There should be an entry, good or bad! What's the result of the command fwengmon /C | find ":3380"? Any chance to take a NetMon trace on the ISA external interface? HTH, Stefaan
RE: Port Forwarding / Redirection with ISA 2006? - 29.Apr.2007 9:47:24 AM
CODES
In what shell should I run that command?
RE: Port Forwarding / Redirection with ISA 2006? - 29.Apr.2007 12:47:57 PM
Hi Holger, just open a command windows and run that command. If it's not in the path, it might be in the directory "C:\Program Files\Microsoft ISA Server>". If you couldn't find it on the ISA box, download it from Firewall Kernel Mode Tool for ISA Server 2006. HTH, Stefaan
