Port Forwarding Question
All Forums >> [ISA 2006 Publishing] >> Server Publishing >> Port Forwarding Question Page: [1]
Port Forwarding Question - 21.May2008 5:59:49 PM
prologic
I'm trying to forward some ports to a machine on the internal network.
I've looked up the documentation, and it says it needs ports, 90 and 3000 forwarded to it using both TCP and UPD.
Are the correct settings going to be making a new protocol with
"Incoming" TCP Port 90
"Incoming" TCP Port 3000
"Receive Send" UDP Port 90
"Receive Send" UDP Port 3000
Or should that be
"Receive" UDP Port 90
"Receive" UDP Port 3000"?
Also I already have a similar rule set up but it ocassionally throws a "No valid network listener, need a relationship" error. Any ideas how to overcome this?
Thanks a lot!
RE: Port Forwarding Question - 12.Jun.2008 10:37:13 AM
Recieve Send is correct.
Make sure your Network Rules are correct and that there aren't any conflicting rules.
Make sure you select a specific IP address, instead of an entire Network for the Server Publishing Rule.
(in reply to prologic)
