Port forwarding
Port forwarding - 24.Jan.2007 10:27:31 AM
Zulan
Hello! Today I'm using a checkpoint firewall and I have tons of what they call "address translation" rules. They are just simple port forwarding rules. I am evaluating ISA server 2006 to replace this server but I can't find the equivalent of address translation anywhere in ISA server 2006. Any idea where I can find the settings or how I create them?
RE: Port forwarding - 24.Jan.2007 10:53:53 AM
sloppyjones
port forwarding is also called a publishing rule in isa. many protocols are alreay loaded in isa, or you can make your own by making a non-server publishing rule and specify port etc.
RE: Port forwarding - 25.Jan.2007 3:28:18 AM
Zulan
I guess I misused the word port forwarding since that wasn’t was I was after. Let’s create a scenario. I have a web server in my LAN running on port 80. I want to publish this on port 200 without changing the port on my webserver. In the checkpoint world I create an access rule for port 200. I then create an address translation rule translating port 200 to port 80 forwarding it to my internal webserver. It’s almost as it’s a part of the publishing rule and really easy to do and find. Even my home d-link router has this option whenever you publish something, but there it’s called Private and Public port.
RE: Port forwarding - 25.Jan.2007 3:58:47 AM
Zulan
Ahh, I finally found it. Here’s what you do. You create a new Non-web server publish rule. When it asks you for protocol, choose port 200, then press the port button. Under Published Server Ports choose “Send requests to this port on the published server” and choose port 80. Done, working just the way I want.
RE: Port forwarding - 27.Jan.2007 12:25:03 PM
Hi Zulan, That's one way to do it. The other would be to configure the Web listener to listen on TCP 200. That way you get the application layer inspection from Web Publishing Rules. HTH, Tom
RE: Port forwarding - 31.Jan.2007 5:35:52 AM
Zulan
Yes, that would be a prefered way. That's the way I was trying to do it and that's the reason I had this problem initially. This is beacuse if you configure it as a published web rule, the "port" button that I mentioned is no longer there so you can't really do it with applicaciton layer instpection or am I doing something wrong?
