Postini and ISA 2006
All Forums >> [ISA 2006 Publishing] >> Exchange Publishing >> Postini and ISA 2006 Page: [1]
Postini and ISA 2006 - 9.Jun.2010 10:13:44 AM
neilbarker
I have been asked to add the following IP ranges to my ISA 2006 server in order for Postini to deliver email to my Exchange server:
Inbound port 25:
IP Range: 207.126.144.0 - 207.126.159.255
IP/Subnet Mask Pair: 207.126.144.0 / 255.255.240.0
CIDR Range: 207.126.144.0 / 20
I can't seem to get this right and all their tests are failing. Has anyone done this before who can assist?
Many thanks
Neil
RE: Postini and ISA 2006 - 9.Jun.2010 10:27:09 AM
Hi Neil,
Use the Mail Server publishing wizard to create the necessary SMTP publishing rule as discussed here:
http://technet.microsoft.com/en-us/library/bb794751.aspx
Create a new computer set called 'Postini Mail Relays', edit the properties of this set, then add a subnet object for: 207.126.144.0 / 20
Once you have created the computer set, add the 'Postini Mail Relays' computer set to the From tab of your SMTP publishing rule.
(in reply to neilbarker)
RE: Postini and ISA 2006 - 9.Jun.2010 10:58:56 AM
neilbarker
Thanks Jason.
I have tried that and rerun the Postini tests. I still get the same result:
Error
Unable to send SMTP message test: 550 - MAIL FROM failed.
The email server is not available. Check your firewall or email server for settings that might be preventing delivery.
What else could be preventing this?
Thanks in advance.
RE: Postini and ISA 2006 - 9.Jun.2010 11:02:07 AM
Back to basics...can you telnet to port 25 on your mail server external address from an Internet host?
You will need to remove the Postini computer set from the "from" tab to do this...
RE: Postini and ISA 2006 - 9.Jun.2010 11:08:14 AM
neilbarker
I cannot telnet at the moment as I am on a Windows 7 PC and do not have telnet (unless you know of a way to do it on 7)
Perhaps you could try for me - mailgate2.qccis.com
We are currently receiving email to our Mime Sweeper server that does our content filtering before it hits the Exchange server.
We are moving to Postini, but before we can I need to get the firewall sorted out.
Not sure if I am barking up the wrong tree here but do I need a new receive connector on my Exchange 2007 server?
RE: Postini and ISA 2006 - 9.Jun.2010 11:10:45 AM
neilbarker
Jason, in addition to the last post I already have a couple of mail server publishing rules in place.
Would they cause a conflict when I am testing?
RE: Postini and ISA 2006 - 9.Jun.2010 11:24:26 AM
I can telnet on port 25 successfully and my test email was accepted for delivery!
220 SMTP Relay
ehlo
250-qcc.co.uk
250-SIZE 31457280
250-ETRN
250-ENHANCEDSTATUSCODES
250-DSN
250-VRFY
250-AUTH
250 8BITMIME
mail from:jason.jones@silversands.co.uk
250 2.0.0 jason.jones@silversands.co.uk OK
rcpt to:test@qccis.com
250 2.0.0 test@qccis.com OK
data
354 Ready for data
test
250 2.0.0 Message received OK
Looks good to me...
RE: Postini and ISA 2006 - 9.Jun.2010 11:27:02 AM
Do their tests work if you leave don't limit to their source IP addresses?
Are you sure they have given you the correct source IP addresses?
Error 550 normally means "cannot relay" so they are probably connecting but you need to define them as an allowed relay host or similar...
RE: Postini and ISA 2006 - 9.Jun.2010 11:30:07 AM
neilbarker
Yes that all works on the existing setup for email coming to ISA then being passed to Mimesweeper and then on to Exchange
What I can't get working is Postini's test email page. It allows you to test their connection to your mail server. So mail comes into ISA and then straight to Exchange - bypassing Mimesweeper (the aim is to get rid of the internal mimesweeper server and then replace with external Postini scanning).
RE: Postini and ISA 2006 - 9.Jun.2010 11:33:39 AM
neilbarker
I originally created the SMTP publishing rule using ANY in the from tab and even this did not work.
I have had the IP's confirmed twice by email from 2 different support people so I guess they are correct.
I am sure I am missing something but can't put my finger on it.
Do you know where I should define them as allowed to relay?
Neil
RE: Postini and ISA 2006 - 9.Jun.2010 11:43:28 AM
neilbarker
Found this in the ISA server app log:
The server publishing rule Postini Incoming SMTP Server, which maps 10.1.0.13:25:TCP to 188.220.57.67:25 for the protocol SMTP Server, was unable to bind a socket for the server. The server publishing rule cannot be applied.
Could it not bind a socket as port 25 is already in use?
RE: Postini and ISA 2006 - 9.Jun.2010 11:48:33 AM
Are you trying to use multiple server publishing rules with the same address and port?
RE: Postini and ISA 2006 - 9.Jun.2010 11:51:15 AM
neilbarker
I certainky was Jason.
I then disable the old one and enabled the new one and saw the follwing in the ISA app log:
A problem preventing application of the server publishing rule Postini Incoming SMTP Server that maps 10.1.0.13:25:TCP to 188.220.57.67:25 for the protocol SMTP Server was resolved. This rule was previously ignored.
Which told me the new rule had bound to port 25. I re ran the Postini test and my email came through.
Many thanks for all your assistance in helping me resolve this problem.
RE: Postini and ISA 2006 - 9.Jun.2010 5:37:03 PM
Cool, no problem!
