Prevent split tunnel?
All Forums >> [ISA 2006 Firewall] >> VPN >> Prevent split tunnel? Page: [1]
Prevent split tunnel? - 9.Jun.2008 8:42:17 AM
pread
Hi there,
Is there any way to prevent users using split-tunnel VPN via configuration on the ISA 2006 itself?  I've had a google and read the ISA 2006 migration guide book but am still none the wiser....  Presume not possible actually, but thought I'd get confirmation if that is the case :)
Cheers,
Peter
RE: Prevent split tunnel? - 9.Jun.2008 9:27:28 AM
paulo.oliveira
Hello,
what do you mean "split-tunnel"? Prevent users to make their computers bridge between internet and internal network when connected to VPN?
Paulo Oliveira.
(in reply to pread)
RE: Prevent split tunnel? - 9.Jun.2008 9:30:32 AM
pread
Basically I want to force users to use the remote ISA server as their default gateway when they connect with the VPN client.  Regardless of the 'use remote gateway' setting in the client itself.
(or I could probably live with it refusing connection if that checkbox is cleared.  Or open to other suggestions :) )
(in reply to paulo.oliveira)
RE: Prevent split tunnel? - 9.Jun.2008 9:44:44 AM
justmee
Yes, with ISA addons:
http://www.winfrasoft.com/vpnq.htm
Not sure about this:
http://fesnouf.online.fr/qss-whatisVPN-q.htm
Or if you a script master, you can mess with Microsoft's VPN-Q crap.
Regards!
(in reply to pread)
RE: Prevent split tunnel? - 9.Jun.2008 10:01:38 AM
paulo.oliveira
Hi Peter,
this is not an ISA configuration, this is a client configuration. So, what you can do is set a policy to prohibit the users from modify the conection properties.
Paulo Oliveira.
(in reply to pread)
RE: Prevent split tunnel? - 9.Jun.2008 10:23:39 AM
pread
Absolutely Paolo :)  I guess I need to look at NAP / quarantine / something....
(basically I'm concerned about non-managed clients, and thought there might be a "drop connection if it wants to use a different gateway" config option server side)
RE: Prevent split tunnel? - 9.Jun.2008 10:46:57 AM
justmee
Hmmm, maybe ...
But how does ISA know if the client is not cheating ?
NAP is not working with ISA.
(in reply to pread)
RE: Prevent split tunnel? - 9.Jun.2008 11:55:20 AM
Status: online
If you define the VPN connection profile using CMAK, you have options to force the default gateway to send traffic via the VPN only.
I think the option is called "make this connection the client default gateway" and is the equivalent of "use default gateway on remote network" available in manually created VPN connection entries.
With CMAK, the users cannot easily disable this otpion
This may help?
Jason Jones (MVP)
(in reply to justmee)
RE: Prevent split tunnel? - 9.Jun.2008 5:05:11 PM
Yep, CMAK is the asnwer, check this article : http://www.isaserver.org/img/upl/vpnkitbeta2/cmak.htm
(in reply to pread)
RE: Prevent split tunnel? - 9.Jun.2008 7:44:58 PM
Status: online
Thanks Tarek
Text from the above link:
A critical setting is the Make this connection the client’s default gateway. This option forces the VPN client to use the VPN link to connect to all non-local networks (all networks that VPN client is not directly connected to). This prevents the VPN client that has not been configured as a Web Proxy and/or Firewall client from connecting to the Internet. Requiring the VPN clients to use the VPN interface as their default gateway prevents VPN clients from circumventing firewall policy when connected to the network. If you disabled the Make this connection the client’s default gateway, it would have the same effect as allowing users to connect modems to their desktops to get around your firewall policy. Please refer to ISA Server 2000 VPN Deployment Kit document Forcing Firewall Policy on VPN Clients
Jason Jones (MVP)
(in reply to elmajdal)
RE: Prevent split tunnel? - 10.Jun.2008 9:52:17 AM
justmee
It boils down to one man's definition of defining "to prevent".
Maybe this "is zee answer" ?
RE: Prevent split tunnel? - 10.Jun.2008 5:15:00 PM
Status: online
Cryptic as ever J...
How about you define a "traditional DMZ"
Jason Jones (MVP)
RE: Prevent split tunnel? - 11.Jun.2008 7:54:26 AM
justmee
Why am I cryptic Jason ?
Isn't this ("to prevent") in the game we play ?
Isn't this ("definition") moving through time as challenges and attacks change as this time goes by ?
Isn't this ("of defining") a way to understand, say a threat from the point/position we're standing ?
Isn't this point of observation relative, a bi-directional relativity, the point to the object we observe and the object to the point of observation  ?
Don't we bring in the end all the pieces together and complete the puzzle ?
So what's cryptic with the "definition of defining" ?
Maybe is just my unfortunate way of speaking english, as I'm not a native english speaker.
I should have a few words with my english teacher ...
Damn, I don't think I can really do that, he was I ...
What about you Jason, can't we consider the association of "traditional" with "DMZ" a cryptic result ?
Is it a well understood/defined/implemented concept ?
Or it has to deal with the "definition of defining" of someone ?
On a sunny summer day watching the crystal blue sky, I might bite the "traditional DMZ" bait....
< Message edited by justmee -- 13.Jun.2008 2:26:44 PM >
