Problems with communication DMZ and Internal
All Forums >> [ISA Server 2004 Firewall] >> DMZ >> Problems with communication DMZ and Internal Page: [1]
Problems with communication DMZ and Internal - 17.Feb.2006 3:19:53 AM
MikeRM2
Hello,
  I am having a problem with ISA Server 2004.  I have set up my network to include a DMZ, but I have no communication between the perimeter server and the main servers.  I have 4 servers running, Server 1 runs the domain with AD, DNS, DHCP, DFS, and the Print Server.  Server 2 also runs AD, SQL, DNS.  These are both on the internal domain (192.168.0.x).  Server 3 is my ISA Server, it is a tri-homed server with the following NIC connections, External (10.0.0.x), Perimeter (172.16.0.x), and Internal (192.168.0.x).  The only thing running on this server is ISA.  Server 4 is my perimeter server on the perimeter network (172.16.0.x), it runs my web server, Exchange, and is setup to be my backup server.  All Internal and Perimeter NICs have the gateway of the ISA Server, on their respective IP addresses.  My ISA server is set up with the following network rules: Perimeter - External, Perimeter (Source) External (Destination), Route; Perimeter - Internal, Internal (Source) Perimeter (Destination) Route; Internal - External NAT.  It also contains the following access rules:  DNS Perimeter to Internal Publishing Rule, Server 1 to Perimeter network with DNS Server protocol open;  DNS Internal to External, Server 1 to Perimeter with DNS Server protocol open; Outbound DNS Internal DNS Server, Allow DNS protocol, Server 1 (Source), External (Destination); Inbound to Perimeter Web Server, Allow HTTP / HTTPS, External (Source), Server 4 (Destination); Inbound to Perimeter SMTP Server, Allow SMTP / SMTPS, External (Source), Server 4 (Destination); Internal to Perimeter communication, Allow ADLogon/DirRep / DirectHost (TCP 445) / DNS / Kerberos-Adm (UDP) / Kerberos-Sec (TCP) / Kerberos-Sec (UDP) / LDAP (TCP) / LDAP (UDP) / LDAP GC / RPC Endpoint Mapper (TCP 135) / NTP / Ping, Server 4 (Source), Server 1 (Destination).  On all internal NIC and Perimeter NICs, NETBios has been enabled, it is disabled on the External NIC.  I have been able to log Server 4 onto the Internal domain, and it has been added to AD and the DNS server.  All the addresses are correct.  I have done a nslookup of external websites from server 4 and they produce the correct information.  Now I am unable to ping any websites from Server 4, it gives Destination Host Unreachable.  I can ping any of the internal servers or client computers.  I have looked in Network places and am unable to see Server 4 from the Internal servers, including the ISA server.  Also I am unable to see any other server from Server 4.  I am unable to activate or update Server 4, due to it's lack of connectivity.  I am wondering what I have missed in my setup?  I would appreciate any help.
Thank you
RE: Problems with communication DMZ and Internal - 20.Feb.2006 3:56:37 PM
Status: online
Hi Mike,
TMI!
Can you  break it down for us?
(in reply to MikeRM2)
RE: Problems with communication DMZ and Internal - 20.Feb.2006 5:30:17 PM
MikeRM2
Alright, I'll see if I can break this down a bit:
                                                       Internet
                                                            |(10.0.0.X)
                                                       ISA Server ---------------Perimeter Server (172.16.0.X)
                                                       Internal Network (192.168.0.X)
Now I set up the rules as outlined in Chapt. 7 of ISA Server 2004 for Intradomain communication.  I can log on from my perimeter server to the domain, and it registered with DNS as 172.16.0.X which is correct.  But I am unable to see the perimeter server otherwise.  I have no internet access on the perimeter server, and tried to publish updates through WSUS to the perimeter server to no avail.  Basically, other than the AD login communication, I have no contact with the perimeter server.  Hopefully this helps a little.
RE: Problems with communication DMZ and Internal - 26.Feb.2006 7:53:19 PM
Status: online
Hi Mike,
OK, what rules do you have in place to allow the communications that should be working but are not working?
Have you created all the required Network Rules?
RE: Problems with communication DMZ and Internal - 28.Feb.2006 5:01:30 PM
Status: online
have you doubled check your configuartion with this article :
Allowing Intradomain Communications through the ISA Firewall (2004)
http://www.isaserver.org/articles/2004perimeterdomain.html
RE: Problems with communication DMZ and Internal - 21.Mar.2006 3:21:27 PM
MikeRM2
Ok Tom,
  Sorry it has been so long, I have been away.  But I am not sure what rules I have in place that are not working.  I have 9 Firewall policy rules in place, and 5 network rules in place.  I set most of them up following your book.  I am just not sure where I went wrong, they should be working.
RE: Problems with communication DMZ and Internal - 21.Mar.2006 3:22:10 PM
MikeRM2
ORIGINAL: elmajdal
Tried don't work
(in reply to elmajdal)
RE: Problems with communication DMZ and Internal - 26.Mar.2006 6:41:04 PM
Status: online
Hi Mike,
They do work. You need to review what you did differently than what was explained in that article.
