Problems with email
All Forums >> [ISA Server 2000 Firewall] >> General >> Problems with email Page: [1]
Problems with email - 9.Apr.2003 1:49:00 PM
fiona
Firstly, thank you for your help with authentication issues, which now works properly! New problem...when the site & content rules are enabled, no external mail at all are sent or received, the outgoing mail just sits in the queue. As soon as the 'Allow all' rule was enabled again, all mail that was in the queue was sent. We are using SMTP/POP3 server, and the ISA Server has been configured exactly as recommended in the article 'ISA Server SMTP Server Support'.
Any suggestions??
RE: Problems with email - 9.Apr.2003 3:06:00 PM
AttilaKaanSalci
Hi Fiona,
is your smtp/pop3 server behind isa or is an external server?
Your server/clients are Firewall or SecureNAT clients?
It may be that you're having the same problem as me.
Kaan
(in reply to fiona)
RE: Problems with email - 9.Apr.2003 3:19:00 PM
fiona
The SMPT/POP3 server is behind ISA, and the clients are SecureNAT clients.
[ April 09, 2003, 03:20 PM: Message edited by: Fiona ]
(in reply to fiona)
RE: Problems with email - 9.Apr.2003 3:37:00 PM
AttilaKaanSalci
Hi Fiona,
you should have at least one allow rule, at least for a specified client address set.
I think it may depend on your site and content rules.
could you give some detail?
kaan
(in reply to fiona)
RE: Problems with email - 9.Apr.2003 3:45:00 PM
fiona
I have about 6 groups, each have a specific destination set that consists of the websites which they can visit, anything that is not in the destination set is not allowed and users are redirected to a website telling them this. Each of these groups then has an allow rule that allows them access to their destination set and a deny rule that denies them access to all destinations excepted the selected destination set. This part is working ok, and restricting users as expected.
The 'Allow all' rule which i mentioned earlier is a rule that allows all users access to all destinations.
(in reply to fiona)
RE: Problems with email - 9.Apr.2003 3:51:00 PM
AttilaKaanSalci
OK, that was what I'm in trouble with.
It seems that the explicit or implicit deny of a Internet resource (lets say *.domain.com or deny all except that implicitly denies *.domain.com) causes also the firewall deny not only website (browser protocols http, https, ftp etc) but also the rest of the protocols (as smtp/imap4/pop3 etc).
Also my trouble is howto deny web protocols on a specific destination set, but allow the rest of the protocols go.
It may be that Tom or some other guru could hep us.
Kaan
(in reply to fiona)
RE: Problems with email - 10.Apr.2003 11:05:00 AM
fiona
Hi Kaan,
Have you applied a Site & Content rule to your administrator account, or whatever account you user to log onto your server? I think that may have been my problem as it seems to be working for me now...
See 'Create Site and Content Rules and Protocol Rules to Support Internal Servers' part of the article at: http://www.isaserver.org/tutorials/smtpauth1.html
(in reply to fiona)
RE: Problems with email - 10.Apr.2003 9:46:00 PM
Hey guys,
check out the ISA log files. They will tell you exactly why the requests are blocked. Keep in mind that servers must be configured as SecureNAT clients because it is not recommended at all to install the Firewall client on them. Therefore, if internal servers need outbound access, you must allow the protocols in a protocol rule and the destinations in a site&content rule and apply those rules to a client address set.
To get the most information out of the logfiles, I strongly recommend to enable the logging of all fields. In the MMC, go to the node Monitoring Configuration, then select Logs. In the details pane, right-click the applicable service and then click Properties. On the Fields tab, click Select All.
A lot of people seem to have problems with interpreting the logfiles. It isn't that difficult, but you should first understand what is logged. In the ISA helpfile there is a section called Firewall and Web Proxy log fields, a must read. Additional information can be found in the article http://support.microsoft.com/default.aspx?scid=kb;en-us;Q284818 .
(in reply to fiona)
RE: Problems with email - 11.Apr.2003 12:51:00 PM
AttilaKaanSalci
I think I've resolved my problem.
All the clients of my ISA (Server or PC Desktop) are SNAT clients. The PC Desktops are also WebProxy clients.
I have a protocol rule that allows unauthenticated access to a set of protocols for any request. Another rule that enforces authentication on browser protocols.
I've added another protocol rule that enables all protocols without authentication to a specific client address set (servers and some administrative clients).
I leave the default allow site and content rule enabled and created a new site and content rule that denies specified dest set of domains.
I've also configured HTTP filter to forward requests to Web Proxy service.
In this manner, if a client or server tries to connect with browser protocols to one of the denied sites it will be forwarded to the web proxy that will deny the destination. Else if the client tries to connect to a denied destination with other ip protocols (i.e. smtp, pop3, imap4 etc) it will pass by the allow rule and the unauthenticated protocol rule.
But what a mess, other firewall software, permits you to specify destination:port in every rule. i think ISA is not a flexible tool.
Kaan
(in reply to fiona)
RE: Problems with email - 12.Apr.2003 1:19:00 PM
Hi kaan,
I've put it on the ISA server wish list a long time ago! [Big Grin]
Check out http://forums.isaserver.org/ultimatebb.cgi?ubb=get_topic;f=18;t=000008 for more info.
(in reply to fiona)
