Publish OWA and Activesync at the same time using SSL
All Forums >> [ISA Server 2004 General ] >> Server Publishing >> Publish OWA and Activesync at the same time using SSL Page: [1]
Publish OWA and Activesync at the same time using SSL - 12.May2008 8:40:49 PM
dekkar
Hello all.... I have finally worked out how to publish activesync via SSL....
But I have a problem....
The difference between publishing OWA and Activesync is that the web listener authentication method for OWA is Forms Based, and for Activesync you untick them all..
Now the problem I am having is I cant publish them both at the same time....
If I create an Activesync rule, I get an error when trying to add the OWA rule...
When adding the web listener in the wizard I get the error "A web listener that listens on similar IP and port is already in use by the rule "activesync SSL". Web listener IP addresses and ports used by different rules cannot overlap"
I tried to merge these rules, but then I have a problem with using either one web listener or the other....
How do I get these services running at the same time...??
Dekkar
RE: Publish OWA and Activesync at the same time using SSL - 13.May2008 2:20:02 AM
dekkar
Ok.... I ran through the instructions as per http://www.isaserver.org/tutorials/2004pubowamobile.html and it looks like Activesync is working whereas I cant add the Localhost SSL cert to the Localhost-Exchange Rule.... It just isnt there..
I went throught the creation of a certificate using an internal CA server, and can see it if I go into MMC --> certificates.... But it doesnt show up when I'm configuring the web listener.....
Not too sure what I'm doing wrong...
one thing, when creating the cert, the default Type of certificate needed is a "client authentication certificate" is this the correct one?
< Message edited by dekkar -- 13.May2008 2:21:32 AM >
(in reply to dekkar)
RE: Publish OWA and Activesync at the same time using SSL - 19.May2008 10:23:40 AM
excossack
Do you use OMA as well?
