Publish SMTP and IMAP
All Forums >> [ISA 2006 Publishing] >> Exchange Publishing >> Publish SMTP and IMAP Page: [1]
Publish SMTP and IMAP - 23.Nov.2006 9:01:05 AM
boozzard
In a test environment i am trying to publish IMAP and SMTP. I have followed the wizard through and the rules show up in the firewall policy. Also the fwengmon.exe utility is showing these as created properly:-
C:\ISA\tools>fwengmon.exe /c
Creation Objects:
ID      Protocol  Source                Destination             One-Shot
1       TCP(6)    0.0.0.0:0             10.10.0.48:1745         No
2       TCP(6)    0.0.0.0:0             10.10.0.48:8080         No
2791    TCP(6)    0.0.0.0:0             195.149.121.121:25      No
2790    TCP(6)    0.0.0.0:0             195.149.121.121:143     No
Both the rules don't seem to work. I start to see issues when looking at a netstat
C:\ISA\tools>netstat -na| find "LIST" | find "195.149.121"
TCP    195.149.121.121:25     0.0.0.0:0              LISTENING
TCP    195.149.121.121:139    0.0.0.0:0              LISTENING
TCP    195.149.121.121:1403   0.0.0.0:0              LISTENING
TCP    195.149.121.121:1416   0.0.0.0:0              LISTENING
As you can see the IMAP rules isn't working as its not listening on port 143. Also i can't telnet the exchange server on 143 from the ISA 2006 server. Also, checking the smtp rule (this i can telnet from the isa2006 server) but i see the following when telneting  the external IP on port 25.
C:\>netstat -n |  find ":25"
TCP    10.10.0.48:5376        10.10.0.6:25           SYN_SENT
TCP    195.149.121.121:25     195.149.121.121:5375   ESTABLISHED
TCP    195.149.121.121:5375   195.149.121.121:25     ESTABLISHED
As you can the connection is established to the ISA server but the connection cannot be made to the internal exchange server.
I am really confused, the network config is setup as an edge firewall.
Any help would be greatfully received
RE: Publish SMTP and IMAP - 28.Nov.2006 11:16:30 AM
You can ignore the netstat information -- that's useless when evaluating ISA Firewall listeners.
Make sure the SMTP and IMAP services are enabled on the Exchange Server
Make sure that the Exchange Server is a SecureNAT client
Double check for typos in your rule.
(in reply to boozzard)
