Publishing OWA FBA and OMA using ISA 2004
Publishing OWA FBA and OMA using ISA 2004 - 23.Aug.2006 2:53:36 AM
gbeckett
I am aware of the problems of publishing both FBA and Basic authentication with a single IP address and Web Listener so we have purchased a second IP address to bind to the external interface of the firewall. What I am looking for is an article or step by step advise on how to go about binding the address and publishing OMA and ActiveSync on a second Web Listener. This is a production environment and OWA FBA is already published and working and I do not want to screw that up hence the request for advise. I read an excellent article, ISA Server 2004: Supporting Both Basic and Forms-Based Authentication with a Single External IP Address and Web Listener (v1.1) by Thomas Shinder but the warning that went along with the article was enough for the powers that be to decline on going forward with that method. Thanks in advance
RE: Publishing OWA FBA and OMA using ISA 2004 - 28.Aug.2006 4:05:04 PM
Hi G, Create a second Web listener and bind the second certificate to that listener, make sure the listener is using basic authentication and is delegating basic credentails. Of course, the ISA firewall will be a domain member so that you can auth the user. Make sure that both listeners are listening on a specific IP addresses, and that a different FQDN is assigned to each IP address. HTH, Tom
RE: Publishing OWA FBA and OMA using ISA 2004 - 30.Aug.2006 3:54:48 AM
gbeckett
Hi Tom Thanks for your response, apologies for the delay in my response. I have a good idea how this should be done but I guess my biggest worry is adding the additional address to the external NIC. Will this have a ramification to the rules that are already configured within ISA? I cannot afford for this to go wrong! Regards
RE: Publishing OWA FBA and OMA using ISA 2004 - 6.Dec.2007 7:38:55 PM
subtitling
Hi Mr Shinder, Are there any step by step guides, or other, using two IPs on one NIC? I have an ISA 2004 publishing OWA FBA for our Exchange 2003 which is on the trusted interface (local LAN). I need to publish OMA. I have spare IPs I can use, but I don't understand how to create and bind in the way you suggest below. We have a certificate from Startcom called webmail.ourdomain.com. Do I need to get another certificate for the OMA listener, e.g. webmail2.ourdomain.com? Our ISA server is the sole firewall, so it has only one external NIC. Many thanks Karl quote:
ORIGINAL: tshinder Hi G, Create a second Web listener and bind the second certificate to that listener, make sure the listener is using basic authentication and is delegating basic credentails. Of course, the ISA firewall will be a domain member so that you can auth the user. Make sure that both listeners are listening on a specific IP addresses, and that a different FQDN is assigned to each IP address. HTH, Tom
RE: Publishing OWA FBA and OMA using ISA 2004 - 7.Dec.2007 10:53:56 AM
NO INTERFACE IS TRUSTED! That is a core security feature of the ISA Firewall. You can add a second IP address to the external interface of the ISA Firewall, so that you can bind the second certificate to that. It's in the Advanced TCP/IP configuration. HTH, Tom
RE: Publishing OWA FBA and OMA using ISA 2004 - 7.Dec.2007 11:41:35 AM
subtitling
ORIGINAL: tshinder NO INTERFACE IS TRUSTED! That is a core security feature of the ISA Firewall. Thank you for your swift reply. 'Trusted' is a figure of speech to describe the interface where the local users are, viz, the Exchange is a part of the Internal network. 'Trusted' is a phrase Watchguard used, much like Microsoft use 'Internal'.quote:
You can add a second IP address to the external interface of the ISA Firewall, so that you can bind the second certificate to that. It's in the Advanced TCP/IP configuration. HTH, Tom If for the mean time I switched all access, OWA and OMA to Basic, would this decrease the security of the connections? Like I said, ISA 2004 is 'Front Ending' the Exchange 2003 and is our sole 'External' defence device. Many thanks Karl
< Message edited by subtitling -- 7.Dec.2007 11:42:41 AM >
RE: Publishing OWA FBA and OMA using ISA 2004 - 9.Dec.2007 11:36:33 AM
Hi Karl, As long as you're using SSL to SSL bridging, there are no negative security issues with using Basic authentication. HTH, Tom
RE: Publishing OWA FBA and OMA using ISA 2004 - 13.Dec.2007 9:20:06 AM
OWA FBA and OMA, ActiveSync work with the same listener and IP address when using ISA 2006, because it falls back to basic. ISA 2004 doesn't do this. HTH, Tom
