Publishing Rules not working
Publishing Rules not working - 29.Oct.2006 12:55:53 AM
rodtaylor
Hi Tom, My installation of ISA 2006 is having a problem with Publishing Rules. The setup is: 4 x NICS - Internal 192.168.1.0/24 - External 172.16.0.1/16 - connected to ADSL router 172.16.0.2/16 - DMZ 203.x.x.x/29 - Private Testing Network 192.168.0.0/24 - Internet connection is using an ADSL router in Bridge mode on External network. This works fine for web traffic from all internal networks and routing External to DMZ. Network Rules: - Local Host - All Networks = Route - All Protected - DMZ/External = NAT - Private Networks - Private Networks = Route - External - DMZ = Route I have tried publishing servers in both the DMZ and Internal networks to no avail. Each time I create a rule, it doesn't catch the traffic that I think it should be catching. As an example, I have Published the SMTP server in the DMZ as follows: Publish Non-Web Server Action: Allow Traffic: SMTP Server From: Anywhere To: Mail Server Listen on: All networks Using Telnet and Monitoring I can see that traffic from my Internal workstation to the ISA address on Port 25 is recognised as SMTP and Denied. I expected to see it recognised as SMTP Server and forwarded on to the Mail Server. The same thing happens to traffic from the External network. I have tried publishing various hosts and protocols in both the DMZ and Internal network but ISA just refuses to catch traffic that is published. For the example above, I have a simple access rule in place to allow my mail server to function for now. I have also checked the rule order and always put the Publishing rules at the top of the list. Any help would be much appreciated. I don't know what other information would be useful but I've included an ipconfig listing below. By the way, the only reason I implemented a DMZ is because these Publishing Rules wouldn't work and I needed to get my Mail server running. Once fixed, I plan to remove the DMZ and put the mail server back in the Internal network. Thanks Rod Windows IP Configuration Host Name . . . . . . . . . . . . : xxxxxx Primary Dns Suffix . . . . . . . : xxxx.com.au Node Type . . . . . . . . . . . . : Unknown IP Routing Enabled. . . . . . . . : Yes WINS Proxy Enabled. . . . . . . . : No DNS Suffix Search List. . . . . . : xxxx.com.au com.au Ethernet adapter Public: Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Intel(R) PRO/1000 PT Dual Port Server Adapter Physical Address. . . . . . . . . : 00-15-17-12-EF-CF DHCP Enabled. . . . . . . . . . . : No IP Address. . . . . . . . . . . . : 172.16.0.1 Subnet Mask . . . . . . . . . . . : 255.255.0.0 Default Gateway . . . . . . . . . : Ethernet adapter Private Links: Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Intel(R) PRO/1000 PT Dual Port Server Adapter #2 Physical Address. . . . . . . . . : 00-15-17-12-EF-CE DHCP Enabled. . . . . . . . . . . : No IP Address. . . . . . . . . . . . : 192.168.0.1 Subnet Mask . . . . . . . . . . . : 255.255.255.0 Default Gateway . . . . . . . . . : Ethernet adapter Head Office: Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Broadcom BCM5708C NetXtreme II GigE (NDIS VBD Client) Physical Address. . . . . . . . . : 00-15-C5-E6-48-7C DHCP Enabled. . . . . . . . . . . : No IP Address. . . . . . . . . . . . : 192.168.1.254 Subnet Mask . . . . . . . . . . . : 255.255.255.0 Default Gateway . . . . . . . . . : DNS Servers . . . . . . . . . . . : 192.168.1.100 Ethernet adapter DMZ: Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Broadcom BCM5708C NetXtreme II GigE (NDIS VBD Client) #2 Physical Address. . . . . . . . . : 00-15-C5-E6-48-7E DHCP Enabled. . . . . . . . . . . : No IP Address. . . . . . . . . . . . : 203.144.20.102 Subnet Mask . . . . . . . . . . . : 255.255.255.248 Default Gateway . . . . . . . . . : PPP adapter XXXXX PPPOE: Connection-specific DNS Suffix . : Description . . . . . . . . . . . : WAN (PPP/SLIP) Interface Physical Address. . . . . . . . . : 00-53-45-00-00-00 DHCP Enabled. . . . . . . . . . . : No IP Address. . . . . . . . . . . . : 203.y.y.y Subnet Mask . . . . . . . . . . . : 255.255.255.255 Default Gateway . . . . . . . . . : 203.y.y.y DNS Servers . . . . . . . . . . . : 203.z.z.z 203.z.z.z NetBIOS over Tcpip. . . . . . . . : Disabled
RE: Publishing Rules not working - 30.Oct.2006 5:20:30 PM
rodtaylor
Hi Tom, Thanks for the reply. I tried changing the Network Rule to NAT but it didn't affect the problem - the Publishing Rules are still not catching traffic. Do you have any other suggestions? Thanks Rod
RE: Publishing Rules not working - 31.Oct.2006 8:03:25 AM
Hi Rod, Wait a minute. You can just change things from Route to NAT that easily. Are you using public addresses on the DMZ? If not, how could route have ever worked? Also, you SMTP rule seems strange. Listen on All Networks? Where did you see guidance that suggested that kind of configuration? Thanks! Tom
RE: Publishing Rules not working - 31.Oct.2006 8:17:55 PM
rodtaylor
Hi Tom, Your question about using Route instead of NAT didn't seem to me to have any bearing on the issue but I thought I'd try it just in case. That seemed a better option than arguing with you and not getting any further help. After testing NAT, I changed it straight back to Route as we are using Public IP's in the DMZ. I knew the routing was working as Access rules worked fine. The problem was caused by using a PPPOE connection to the Internet. I have changed the configuration to use the router as a router instead of a PPPOE "bridge" and it is working beautifully now. What have I learned from this? Do not usa PPPOE on ISA and expect publishing rules to work! During my testing I setup a new network called External PPPOE and included all IP ranges not included in any other network. Then for every Rule where I had External, added the new External PPPOE network. This fixed the problem as the new network was catching the traffic but seemed to be more administrative trouble than it was worth. This approach might help someone in the future who is stuck using PPPOE. Thanks for looking at my setup anyway. Cheers Rod
