Publishing SMTP (not Exchange)
All Forums >> [ISA Server 2004 General ] >> Server Publishing >> Publishing SMTP (not Exchange) Page: [1]
Publishing SMTP (not Exchange) - 28.Feb.2004 8:02:00 AM
deving
I'm attempting to publish an internal Postfix server. On the former firewall, it was a simple matter of poking a hole for port 25 through to the appropriate internal server; this configuration works. Attempting to do the same basic configuration with ISA 2004 isn't working.
If I use a generic publishing rule, the incoming connection never establishes.
If I use the SMTP publishing rule with the SMTP filter activated, the connection is accepted but the internal mail server banner is never displayed and the connection times out.
If I disable the STMP filter (which I would *like* to do; Postfix is extremely thorough about buffer checks), we go back to the behavior of the connection never establishing.
What am I missing?
RE: Publishing SMTP (not Exchange) - 28.Feb.2004 9:38:00 PM
deving
Figured out my own solution. Once I changed the internal host to use the ISA server as the gateway, it all started working.
I blame too little sleep and being up too late. [Smile]
(in reply to deving)
RE: Publishing SMTP (not Exchange) - 28.Feb.2004 10:26:00 PM
Hi Devin,
good to hear you have solved the problem yourself! [Smile]
Whenever you server publish an internal server it should be configured as a SecureNAT client unless you have implemented http://support.microsoft.com/default.aspx?scid=kb;en-us;311777 .
RE: Publishing SMTP (not Exchange) - 2.Mar.2004 12:13:00 AM
Hi Stefaan,
ISA 2004 allows you to choose between full and half NAT by selecting the option in the Server Publishing Rule.
RE: Publishing SMTP (not Exchange) - 2.Mar.2004 7:59:00 PM
oops... never saw it was an ISA Server 2004 forum! [Frown]
RE: Publishing SMTP (not Exchange) - 3.Mar.2004 12:24:00 AM
Hi Stefaan,
No problem!
