Publishing sharepoint with client certificate and Kerberos constrained delegation
All Forums >> [ISA 2006 Publishing] >> SharePoint Publishing >> Publishing sharepoint with client certificate and Kerberos constrained delegation Page: [1]
Publishing sharepoint with client certificate and Kerbe... - 30.Oct.2006 9:31:48 AM
peterbuus
We want to publish sharepoint 2 SP2 through ISA 2006 using client certificate authentication.
For test purposes I made a test installation with a win2003 R2 server acting both as domain controller (for domain TEST in win2003 functional level) and IIS/sharepoint server.
On an other win2003 R2 server i have installed ISA 2006 and configured a sharepoint web publishing rule requiring client certificate and kerberos constrained delegation using SPN "http/sharepoint".
On a third client winXP computer I have installed a client certificate. When hitting the ISA server I am prompted for client certificate - but authentication fails with error code 401 Unauthorized ... (12209)
On the ISA server the monitoring log states an error 12239....requires authorization.  However the Client Username on the logline is TEST/Peter which is the user I have namemapped to the client certificate.
Thus ISA does indeed map my client certificate to the right account, but something goes wrong in the Kerberos delegation.
I am quite confused on how to configure the "http/sharepoint" SPN - I have tried most (all) combinations of
setspn -A http/sharepoint ISASERVER and setspn -A http/sharepoint DOMAINSERVER
and the "Delegation" tab on the ISASERVER/DOMAINSERVER in AD.
Can anybody tell me the correct configuration in my scenario?
Does anybody know how to troubleshoot Kerberos constrained delegation?
Regards / Peter
RE: Publishing sharepoint with client certificate and K... - 30.Oct.2006 12:35:21 PM
peterbuus
I forgot to mention that I already did enable Sharepoint for Kerberos authentication
/Peter
(in reply to peterbuus)
RE: Publishing sharepoint with client certificate and K... - 31.Oct.2006 9:01:05 AM
Hi Peter,
Check this article series out for some help with KCD and User Certificate authentication:
http://www.isaserver.org/tutorials/Configuring-ISA-Firewalls-ISA-2006-RC-Support-User-Certificate-Authentication-using-Constrained-Delegation-Part1.html#
RE: Publishing sharepoint with client certificate and K... - 31.Oct.2006 9:52:23 AM
peterbuus
Hi Tom
I did read your article on OWA publishing and tried my best to copy the setup and configuration to a Sharepoint setup.
However, I still cant make it work.
My ISA server authenticates the User Certificate and maps it to the corresponding user account.
I think the 12209/12239 error I encounter is releated to the subsequent Kerberos delegation.
My ISA setup specifies Kerberos constrained delegation with the SPN http/sharepoint
My understanding is that I further need to
'setspn -A http/sharepoint ISASERVER'
and configure ISASERVER in AD to support kerberos for http/sharepoint as described in your article
Should the delegation work if I (for test purposes) just checked
'Trust this computer for delegation to any service (Kerberos only)'
in the AD delegation tab for ISASERVER?
Is it a problem that my setup is based on vmware and not actual machines?
Peter
RE: Publishing sharepoint with client certificate and K... - 31.Oct.2006 2:20:13 PM
Hi Peter,
No, that option won't work because it implies that the user was originally authenticated by the Kerberos protocol. Selecting 'Trust this computer for delegation to specified services only' *and* selecting 'Use any authentication protocol' is therefore a requirement.
Also, make sure you set the SPN in the web publishing rule to the *real* FQDN of the published web server and not a CNAME.
RE: Publishing sharepoint with client certificate and K... - 1.Nov.2006 10:20:54 AM
Hi Peter,
Listen to Stefaan on this -- he learned from hard experience!
(in reply to spouseele)
RE: Publishing sharepoint with client certificate and K... - 1.Nov.2006 11:07:44 AM
peterbuus
OK - I still cant make it work
I made a new setup with 3 machines
isa.signaturgruppen.dk (ISA server)
dc.signaturgruppen.dk (domain controller)
sharepoint.signaturgruppen.dk (sharepoint)
When I configure a web publishing rule for sharepoint.signaturgruppen.dk ISA suggests the use of SPN http/sharepoint.signaturgruppen.dk
Is it a correct understanding that I should
setspn http/sharepoint.signaturgruppen.dk ISA
and configure ISA server entry in AD to allow kerberos authentication to http/sharepoint.signaturgruppen.dk
- or is it another way around?
/Peter
RE: Publishing sharepoint with client certificate and K... - 1.Nov.2006 1:45:56 PM
ORIGINAL: tshinder
Hi Peter,
Only on this... ?
RE: Publishing sharepoint with client certificate and K... - 1.Nov.2006 2:00:33 PM
Hi Peter,
Assuming 'sharepoint.signaturgruppen.dk' is the *real* hostname and not an alias than the proposed SPN on ISA should be OK.
However, you shouldn't have to execute the command 'setspn http/sharepoint.signaturgruppen.dk ISA'. So, I suggest to remove first your custom SPN with the 'setspn -D' command.
Thereafter, just go to the Active Directory Users and Computers, select the ISA computer account and than the Delegation tab. Now, make sure you select 'Trust this computer for delegation to specified services only' *and* 'Use any authentication protocol'. Next, click the add button and select first the sharepoint computer and than the HTTP service type.
In my case that was enough to get the Kerberos Constrained Delegation working with a FBA and Radius user validation method.
RE: Publishing sharepoint with client certificate and K... - 2.Nov.2006 3:56:03 AM
peterbuus
Hi Stefaan
Thanks a lot - your suggestion solved my problem. Apparently I did some unnecessary SPN panic.....
/Peter
RE: Publishing sharepoint with client certificate and K... - 2.Nov.2006 5:23:46 AM
Hi Peter,
good to hear you have it working and thanks for the follow up!
BTW --- I think that the SPN confusing is created because a 'setspn -L' doesn't show the 'HTTP/' SPNs. You'll have to go through the wizard to find them.
Best Regards,
RE: Publishing sharepoint with client certificate and K... - 23.Mar.2008 10:11:10 AM
no fear
Dears:
I read (http://www.isaserver.org/tutorials/Configuring-ISA-Firewalls-ISA-2006-RC-Support-User-Certificate-Authentication-using-Constrained-Delegation-Part2.html) ...but what if the ISA is in a different domain than the published IIS Server WITH NO TRUST between them??
RE: Publishing sharepoint with client certificate and K... - 3.Apr.2008 9:07:49 PM
It won't work. The ISA Firewall has to be in the same domain.
(in reply to no fear)
