RDP Publishing problem with ISA 2000Std
All Forums >> [ISA Server 2000 General] >> Server Publishing >> RDP Publishing problem with ISA 2000Std Page: [1]
RDP Publishing problem with ISA 2000Std - 31.May2006 5:00:07 PM
Cyrill
Hello everyone.
I've got a problem publishing an RDP server from the internal network with ISA 2000.
The network is organized as follows:
ISA Server (Win2003Server, ISA2000Std) has two NICs:
1. WAN (192.168.1.99/24), which is behind the 3Com HW firewall (192.168.1.254), default GW for this NIC is 192.168.1.254.
2. LAN (192.168.192.1/24), without the default GW.
Within the LAN there is an RDP server (192.168.192.11) under win2000server, which needs to be published to WAN. Default GW of the server is set to 192.168.192.1.
I perform all steps as described here (http://www.isaserver.org/tutorials/Publishing_Windows_2000_Terminal_Services_to_a_NonStandard_Port_.html) and connect my notebook into WAN (192.168.1.140, without default GW) to check the connection.
The problem is that RDP connection works only few seconds (just the time needed to enter my passwd and to see the desktop of published server). Then the connection is dropped.
What should I do to fix that? I'm totally wasted trying every (even mystic =)))  idea to get that working.
Thx in advance.
