RDP problems
All Forums >> [ISA 2006 Firewall] >> Access Policies >> RDP problems Page: [1] 2   next >   >>
RDP problems - 11.Aug.2009 12:02:29 PM
DamianHill
I've setup ISA as a back-to-back firewall to our BT Secure Services firewall.
I am able to see the RDP traffic hitting the ISA firewall but is denied access. I have configured the ISA itself so that I can RDP from an external source over VPN and this works fine, so I tried following a similar setup to the system policy but it still denies the connection.
The rule I've created is...
Action: Allow
Protocol: RDP(Terminal Services)
To: Internal
Users: All Users
I'm pulling my hair out over this so would be very grateful for any help.
RE: RDP problems - 11.Aug.2009 12:23:21 PM
DEVLAVI
Access rule doesn't work here.
You need to publish RDP (Terminal Services) Server on a default  port or an alternative port (Non-Web Server Protocol Publishing rule) to the Internal IP of the ISA, Network listener Should be External.
DEV
(in reply to DamianHill)
RE: RDP problems - 11.Aug.2009 12:52:53 PM
DamianHill
Dev,
Thats for the information, is there a doc or tutorial showing what I need to do - I'm pretty new to ISA server.
Damian
(in reply to DEVLAVI)
RE: RDP problems - 11.Aug.2009 1:29:52 PM
DEVLAVI
Check out this article by Mr.Shinder
http://www.isaserver.org/articles/2004pubts.html
DEV
RE: RDP problems - 11.Aug.2009 6:30:39 PM
DamianHill
I followed the article to the letter but it still fails. When I used a different port I a denied connection with 'Unidentifed IP Traffic(TCP:8888)' - yet I can still RDP from home into the ISA without a problem, I just don't get it.
The article is for ISA2004, I'm using ISA2006 would that make a difference?
RE: RDP problems - 12.Aug.2009 8:27:51 AM
DamianHill
Any ideas guys?
RE: RDP problems - 12.Aug.2009 8:39:47 AM
SteveMoffat
You need a server publishing rule as said above, from your source network to the internal IP address of the server you are trying to rdp to.
Steve
www.isaserver.bm
RE: RDP problems - 12.Aug.2009 9:10:41 AM
DamianHill
Steve,
If I run through the steps I've been through to make this work...
1. Set RDP on ISA to listen on internal network only.
2. Followed http://www.isaserver.org/articles/2004pubts.html (publishing the RDP Server on the ISA Firewall) - which is for 2004, but seems as though it should be pretty much the same for 2006 - only difference being that I chose to publish Non-web server protocols. When following the article I create the port 9999, buit when attempting to connect from external I get access denied...
Client IP: 172.17.0.2
Destination IP: 10.0.0.11
Protocol: Unidentified IP Traffic (TCP:9999)
There is no longer any mention of RDP being denied.
Grateful for any nuggets!
Damian
(in reply to SteveMoffat)
RE: RDP problems - 12.Aug.2009 9:31:42 AM
SteveMoffat
& your forwarding 9999 to 3389?
Steve
www.isaserver.bm
RE: RDP problems - 12.Aug.2009 9:38:28 AM
DamianHill
I'm following exactly the article, there isn't a mention of port forwarding in there - can you explain what I should setup please?
RE: RDP problems - 12.Aug.2009 9:51:10 AM
DamianHill
Steve,
I understand whats needed now, and looking at the article again and my port 9999 is set to pass it through on the default port 3389 so I guess it is forwarded.
Is there anything else I can do to allow the connection?
RE: RDP problems - 12.Aug.2009 9:51:59 AM
SteveMoffat
So you've changed the port that rdp listens on to 9999?
Steve
www.isaserver.bm
RE: RDP problems - 12.Aug.2009 9:58:03 AM
DamianHill
Steve,
On publishing I clicked 'ports' then set the following...
Firewall Ports - Publish on this port instead of the default port:8888.
Published Server Ports - Send requests to the default port on the published server.
I think that this will provide the port forwarding?
Damian
RE: RDP problems - 12.Aug.2009 10:00:56 AM
SteveMoffat
How are you testing this? Over the internet?
Steve
www.isaserver.bm
RE: RDP problems - 12.Aug.2009 10:07:53 AM
DamianHill
Yes. We initiate a VPN connection to the hardware firewall. We then attempt RDP into the network. I have sucessfully used RDP to access the ISA, but have since only allowed it to listen on the internal network.
Hope that makes sense!
RE: RDP problems - 12.Aug.2009 10:15:30 AM
SteveMoffat
you're rule should allow from the vpn network then. not external.
Steve
www.isaserver.bm
RE: RDP problems - 12.Aug.2009 10:21:56 AM
DamianHill
Steve,
It is my understanding that the VPN connection terminates at the Hardware firewall which all traffic hits, then all traffic is handed off to the ISA.
Are you saying I should use the VPN object, or IPSec???
RE: RDP problems - 12.Aug.2009 10:27:46 AM
DamianHill
Steve,
I've gone back to square one and removed all rules. Now an attempt to RDP give the following denied message.
Destination IP:10.0.0.11 (Internal Terminal Server)
Port: 3389
Protocol: RDP (Terminal Services)
Action: Denied Connection
Client: 172.17.0.2
Source: External(172.17.0.2:49277)
Destination: Internal (10.0.0.11:3389)
Looking at the above output do you still think it needs anything further for the VPN connection?
Damian
RE: RDP problems - 12.Aug.2009 11:11:25 AM
DamianHill
Don't know whether this helps narrow down my problem, but I'm also unable to access external to interal using 172.17.0.2 - everything we do appears to be denied.
Post #: 19
RE: RDP problems - 18.Aug.2009 8:45:47 AM
frank_hoof
Is the server that is using RDP client in the internal network zone?
This bothered me quit some time since the network dept decided to change the ip plan...
Post #: 20
