RPC Replication Issue in ISA...
RPC Replication Issue in ISA... - 27.Nov.2007 12:15:30 PM
ISA327
Hey folks, I've been having issue with my Exchange System Manager, and the great guys over at MSExchange.org were able to help me out a lot, but one of the Mods there came to a conclusion regarding my issue that he, and certainly not I quite know how to resolve. Please click here (or http://forums.msexchange.org/Reinstall_Exchange%25%25%25/m_1800456991/tm.htm) to view my post at msexchange.org. Mr. Grogan believes the issue is ISA related... any ideas or help would be greatly appreciated. Thank you. P
RE: RPC Replication Issue in ISA... - 27.Nov.2007 2:08:16 PM
Rotorblade
Hi, I read your post on MSExchange.org concerning the issue you are having with your SBS server. I’m not in anyway an SBS expert but based from the issues you are having and with ISA also running on the same server; it sounds like a Windows Service Pack 2 RSS issue! What SP are you running? http://support.microsoft.com/kb/936594 HTH RB
RE: RPC Replication Issue in ISA... - 27.Nov.2007 5:56:05 PM
ISA327
SP2. Can I remove the ISA Server on Server#1 and set it up on another SBS Server? I'll attempt the resolutions on the KB Article. Thanks.
RE: RPC Replication Issue in ISA... - 27.Nov.2007 6:25:10 PM
Rotorblade
Can I remove the ISA Server on Server#1 and set it up on another SBS Server? Should not have to; just do as directed in the KB and you should be golden! One thing that I have ran into with this is that you may need to update the NIC drivers as well after running the patch and disabling RSS and TCP offloading to get everything working properly. Let us know on the outcome. RB
RE: RPC Replication Issue in ISA... - 27.Nov.2007 6:33:11 PM
Rotorblade
Just to let you know; I posted to your thread on the MSExchange.org to let Andy follow the progress here. Hope it works out for you. RB
RE: RPC Replication Issue in ISA... - 27.Nov.2007 6:40:11 PM
ISA327
Negative... no change.
RE: RPC Replication Issue in ISA... - 27.Nov.2007 9:33:48 PM
Rotorblade
Ok, Reading through your MSExchange.org thread you made reference to your NIC configurations and binding order. From what I could tell you have miss configured the NIC’s. First, with the Network side NIC being disabled, ISA would be considered running in “hork mode”. (single NIC) Running with only one NIC configured, the ISA firewall service is going to cease to function. You need to enable that internal NIC. As I previously mentioned, you may need to update the NIC drivers. I would uninstall the NIC drivers and then reinstall them and restart the server after doing so. Then run through the NIC configurations and set them up properly. Please reference the article below for configuring your NIC’s. http://www.isaserver.org/tutorials/Configuring_ISA_Server_Interface_Settings.html Please check your Internal network properties to make sure you have the correct IP properties. Please post the outcome HTH RB
RE: RPC Replication Issue in ISA... - 27.Nov.2007 9:44:10 PM
Rotorblade
Also, did you apply all the work a rounds mentioned in the KB? Just applying the patch is not going to get it working. Uninstall the NIC drivers and reinstall and apply the work a rounds mentioned in KB....
RE: RPC Replication Issue in ISA... - 27.Nov.2007 11:30:28 PM
ISA327
Okay Rotorblade, will do when I get in tomorrow, I applied the patch remotely. I suppose I've somehow managed to get OWA/Exchange to perform with the configuration using only 1 NIC for sometime by fluke. I'll keep you updated. And thanks again.
RE: RPC Replication Issue in ISA... - 28.Nov.2007 11:57:01 AM
Rotorblade
no updated NIC drivers Did you uninstall and reinstall the NIC drivers? Go to Control Panel, System, Hardware, Device manager, Network adapters and uninstall and reinstall. RB
RE: RPC Replication Issue in ISA... - 28.Nov.2007 12:28:32 PM
ISA327
Uninstalled and reinstalled the NIC's. Went through the Tutorial and the KB Article again. Restarted the Server. No change.
RE: RPC Replication Issue in ISA... - 28.Nov.2007 12:57:23 PM
Rotorblade
RPC service running?
RE: RPC Replication Issue in ISA... - 28.Nov.2007 1:18:48 PM
ISA327
Yes. Started and set at Automatic.
RE: RPC Replication Issue in ISA... - 28.Nov.2007 3:01:10 PM
Rotorblade
Network Connections Advance settings, Adapter bindings; rebind F & P and Client for Microsoft Networks on all apaters and retry. RB
RE: RPC Replication Issue in ISA... - 28.Nov.2007 3:34:28 PM
Rotorblade
If negative results again then will need to get more specifics on your ISA setup. If you could provide (not jeopardizing your security of course ) information on the ISA system policy and firewall access rules, NIC IP specifics etc…. Anything you can provide will help. ISA could be blocking? The ESM relies on Netbios/Winns so I’m thinking down that troubleshooting path. Is your DNS’s zone records correct? Maybe you are using a HOSTS and LMHosts file that needs to be updated with the correct IP? Netbios enabled? Can you ping your server by its host name? RB
RE: RPC Replication Issue in ISA... - 28.Nov.2007 3:37:38 PM
Rotorblade
You may want to consider installing Exchange SP 2?
RE: RPC Replication Issue in ISA... - 28.Nov.2007 3:51:25 PM
ISA327
Okay. Is there an easy way to migrate IIS and ESM to another machine without migrating the problem? Thanks.
RE: RPC Replication Issue in ISA... - 28.Nov.2007 4:29:30 PM
Rotorblade
Is this server accessible from an internal network? From your description it sounds like your just using it for hosting purposes. Internally, the ESM can run from another machine. Other than moving the mail box in AD using the Mailbox move wizard, you would need to use a utility like EXmerge to export and import or do an Exchange store recovery to the new server. It would be a lot of work but that may be your only option. I would not give up the ship just yet! You need to investigate the problem further to determine what gives. RB
RE: RPC Replication Issue in ISA... - 28.Nov.2007 7:06:35 PM
ISA327
Yes, I have a second SBS server available that I can make available on the same internal network. It had another purpose, however I need to get our e-mail back up. What exactly is involved in the transfer? Or better yet what are my options period? Unfortunately, I'm up against a deadline (gulp) that ends tomorrow so I need to get something going here. Thanks again, a ton, for all of your help.
