Remote Management - Web Management
Remote Management - Web Management - 16.Feb.2006 2:02:38 PM
trung
Hi All, Does anyone notice a new feature in System Policy -> Remote Management called Web Management? Any ideas on how to use it? :) By the way, the feature System Performance in Dashboard on my Win2K3 R2 Ent. + ISA Server 2K6 Standard doesn't work. Although this is a fresh installation. How about yours? Does it work? Thanks, Trung
RE: Remote Management - Web Management - 16.Feb.2006 2:48:27 PM
ClintD
System Performance works fine on my install, although it was 'collapsed' when I first went to the console (the expand/collapse option is off to the right).
RE: Remote Management - Web Management - 10.Mar.2006 2:11:38 PM
alans
Hi, I think the web mangement could be two of the following: - If you go to add and remove programes - Add/Remove Windows Component - Application Server - Internet Information Services - World Wide Wed services - Remote Administration (HTML). this is part of the OS
- Or it could be for all the ISA network devices web control.
Regards Alans
RE: Remote Management - Web Management - 12.Mar.2006 9:29:13 PM
Hey guys, System performance doesn't work on mine either. not sure where the bug is, but I've reported it. Web management may be for Windows server management, but there is no ISA Web management interface. HTH, Tom
