Reports failed with SQL 2005 SP2
All Forums >> [ISA 2006 Firewall] >> Logging and Reporting >> Reports failed with SQL 2005 SP2 Page: [1]
Reports failed with SQL 2005 SP2 - 2.May2007 8:27:37 AM
bjwild
I just installed Isa 2006 std in a virtual environment on Windows 2003 R2 Std + Sp2 and changed the logging to a SQL 2005 SP2 Database.
Now everytime i want to make a report it gives me a instant failure with the following alert:
Source: Microsoft ISA Report Generator
Event ID: 21022
The action to summarize all period summaries from the array, into report "1" failed. The error description is: Unspecified error
. Use the source location 1200.193.5.0.5720.157 to report the failure.
Event ID: 21000
The action to connect to ISA Server report data collector on array member ULC-ISASERVER failed.  The error description is: The server threw an exception.
. Use the source location 1201.414.5.0.5720.157 to report the failure.
My database connection goes thru the test, i checked the database and everything works.
I connect to the database as SA
Searching for the event id or keywords havn't gotten me anywhere.
Using MSDE does create reports for me.
Hope someone had this problem and knows the solution
< Message edited by bjwild -- 2.May2007 2:37:27 PM >
RE: Reports failed with SQL 2005 SP2 - 3.Jul.2007 1:52:19 PM
Yorgy
This link might help.
It almost sounds like the problem you may be experiencing.
http://www.microsoft.com/technet/isa/2004/plan/disablelockdownonlogfailure.mspx
HIH
Yorgy
Life is a zoo in a jungle!
(in reply to bjwild)
