Route between two Internal networks
All Forums >> [ISA Server 2004 Firewall] >> Network Infrastructure >> Route between two Internal networks Page: [1]
Route between two Internal networks - 28.Oct.2006 4:50:55 PM
mamo
Hi
I have one ISA server with two nics, External and Internal. Behind my Internal network I have two subnets, A and B and a router between. If my clients on A would like to communicate with B and have ISA server as their default gateway, can ISA server redirect those request to the router that will route to B?
/Marten
RE: Route between two Internal networks - 28.Oct.2006 6:12:29 PM
Hi Marten,
no, internal communications should never touch the ISA server. For more info and how to properly implement such a configuration, check out:
(in reply to mamo)
RE: Route between two Internal networks - 29.Oct.2006 1:00:41 PM
mamo
Hi Stefaan,
Thanks for your answer!
Even though it is not recommended, is it possible to do it?
/Marten
(in reply to spouseele)
RE: Route between two Internal networks - 29.Oct.2006 5:47:17 PM
Hi Marten,
what's your problem in doing it in the right way?
(in reply to mamo)
RE: Route between two Internal networks - 25.Jan.2007 7:02:31 AM
ceba
Why can't we just get the answer to  questions in these forums.  I've asked the same question in differnent ways, with either no anwer or this moralistic IP evangelism,  about ohhh whats right , whats wrong, your going to ip hell if you do that...
The question was CAN it be none,  NOT oh Priest of IP,  MAY i do this and bless the work of my hands.
geeezz
RE: Route between two Internal networks - 25.Jan.2007 3:17:16 PM
Hi ceba,
you have received multiple times the correct answer! I suggest you start to listen...
BTW --- when people like Tom, Clint (a former ISA PSS guy) and myself write articles and/or blogs it is to help other people not to make the same mistakes over and over again.
(in reply to ceba)
RE: Route between two Internal networks - 25.Jan.2007 4:27:23 PM
CyberGuy
You can use Windows to route from subnet A to subnet B; it’s not a function of ISA particularly. I know how frustrating it is when someone won’t give you an answer just because it’s not the appropriate or supported way to do things. Also, “no, internal communications should never touch the ISA server.” is not true in some circumstances like perhaps a server sitting in DMZ. With that said, the correct way would be to set the default gateway on the router to point to the ISA server and the internal clients should have their gateway pointing to the router. If you have some justification as to why you want the ISA server to do the routing, then posting a more detailed reason might get you a better answer.
(in reply to mamo)
RE: Route between two Internal networks - 25.Jan.2007 4:54:59 PM
ceba
ORIGINAL: spouseele
Hi ceba,
Hello stefaan
1st did you read your anwsers or my questions
2nd untrue - the answer given has not answered the questions  if you've looked at any of my questions - you'll note in each one i've asked specific questions with specifiec detail - line item  by line item.
please see this
http://forums.isaserver.org/m.aspx?m=2002036945&mpage=1&key=
Very specific questions and started out saying i'm at a loss in understanding the EAXCT SAME ARTICLES YOU SAY TO READ!!
You just keep pointing me back to were are came from.
BTW - If I understood I wouldn't keep asking, thats why i keep asking.
The answer to what is air isn't - the stuff ya can't see.
< Message edited by ceba -- 25.Jan.2007 5:07:59 PM >
RE: Route between two Internal networks - 25.Jan.2007 5:06:06 PM
Hi CyberGuy,
You are talking about a different scenario:
1. What I'm talking about:
Subnet A ---+
  .         +---[ISA] --- Internet
Subnet N ---+
2. What you are talking about:
Subnet A --- [ISA] --- Internet
Subnet B ------+
(in reply to CyberGuy)
RE: Route between two Internal networks - 25.Jan.2007 5:18:19 PM
ceba
ORIGINAL: spouseele
Hi CyberGuy,
Also, "no, internal communications should never touch the ISA server.” is not true in some circumstances like perhaps a server sitting in DMZ.
Subnet A ---+
Subnet N ---+
Subnet B ------+
My point eaxtly - Never touch means never never never to me  but your little pic say it touches but differently.  It those statement the make us trying to learn this nuts.
Like never touch my daughter (clear right -everyone gets that)
Subnet A -------- [ISA] ------ internet
Subnet B or N you choose -------------------------------------------------->
see thats never touch!!!
perhaps its NOT the class???
RE: Route between two Internal networks - 25.Jan.2007 5:20:09 PM
Hi ceba,
if you want to deal with the more advanced scenario's, we assume you have already a good understanding of the basic ISA stuff and network routing. Therefore the answer posted in http://forums.isaserver.org/m_2002036945/mpage_1/key_/tm.htm#2002036945 said it all!
Here is an example:
Your question:
To ensure everything is reachable both ways is there Firewall Policy required?
My answer:
Make sure that:
2. the network ID's 172.16.2.0/24 and 10.45.1.0/24 can talk with each other without touching the ISA server.
If it shouldn't touch the ISA server, obviously no firewall policy is needed for that communication!
Again, I assume you already understand basic network routing.
(in reply to ceba)
RE: Route between two Internal networks - 25.Jan.2007 5:26:00 PM
Hi ceba,
I clearly said "no *internal* communication".
Scenario 1: traffic between subnet A and subnet N should *not*  loop through the ISA internal interface. This is the network within a network scenario and requires a proper routing infrastructure on the internal network.
Scenario 2: subnet A is internal and subnet B is perimeter. So, my statement doesn't even apply when subnet A wants to talk to subnet B.  In this scenario, ISA controls all the traffic between both networks.
< Message edited by spouseele -- 25.Jan.2007 6:06:20 PM >
(in reply to ceba)
RE: Route between two Internal networks - 26.Jan.2007 4:02:06 PM
CyberGuy
Subnet A ---+
                  +--- [ISA] --- Internet
Subnet B ---+
Subnet B ------+
I agree, that's why mano needs to explain why
Subnet A ---+
               [Router] --- [ISA] --- Internet
Subnet B ---+
won't work.  If mamo wanted to limit, say just HTTP traffic between A and B, then a simple Linksys router wouldn't do that where as a more expensive Cisco router, which may be cost prohibitive, could. Mamo needs to explain why a simple router can't do what's needed.
< Message edited by CyberGuy -- 26.Jan.2007 4:04:58 PM >
RE: Route between two Internal networks - 26.Jan.2007 5:52:04 PM
Hi CyberGuy,
that's just the whole point.
If two networks need to talk to each other in an unrestricted way, in other words they belong to the same security zone, than the ISA server should *not* be in the path at all.  This is the network within a network scenario.
However, when the goal is that the ISA server should control the traffic between both networks then the ISA server *must* be in the path between both networks. That means that both networks belong to different security zones and that they should be reachable from the ISA server through two different interfaces.
As said before, the network within a network scenario requires a proper routing infrastructure on the internal network. I always use the network design as described in my article How to Implement VPN Off-Subnet IP Addresses. It results in a very simple, clean and robust routing infrastructure. Nevertheless, if you have to support hosts on the same Network ID as the ISA internal interface, then you could use the following workaround:
  • All servers should have static TCP/IP settings. Therefore you should add static routes with the 'route -p add' command to all the servers who must talk to the remote internal networks.
  • All clients should normally use DHCP for their TCP/IP settings. If so, you should define those static routes as a DHCP option and they will automatically be assigned to the clients.
For more info, check out TCP/IP Fundamentals for Microsoft Windows.
RE: Route between two Internal networks - 26.Jan.2007 11:51:33 PM
CyberGuy
ORIGINAL: spouseele
Hi CyberGuy,
Yes, agree. I use static routes on ISA so that when I connect from home, 1 hop, to external interface B, returning traffic does not return via interface A, the default gateway, which is about 10 hops. Setting a static route on the router is best, but if needed, setting another IP address for the second subnet would work. I was just trying to get mamo to tell us whether filtering was required, thus routing through the ISA was necessary.
RE: Route between two Internal networks - 17.Jun.2008 12:02:42 PM
Trojan
Good time of day. The situation is next:
initialy I had the network structure like this
Subnet A
after adding the second subnet network now has this structure
Subnet A
Subnet B ------+
As I now, according to the articles about ISA, the ISA server does not interfere in internal traffic, BUT in my case the traffic between subnet A to subnet B and vice versa is blocked even though I specified two internal network cards as internal network as it is usually done.
What can be the cause of this problem?
< Message edited by Trojan -- 18.Jun.2008 11:26:07 PM >
