SMTP Drop connection
All Forums >> [ISA 2006 Publishing] >> Exchange Publishing >> SMTP Drop connection Page: [1]
SMTP Drop connection - 20.Dec.2007 3:07:09 AM
Moresi
Dear All,
I have abrand new Exhcange 2003 installed on the same machine as ISA 2006 Standard. All policies works like a charm, but when I create the publising rule for the SMTP, i try to connect from the outside but the connection close 1 sec after I see the header of the exchange.
You can try with telnet mail.swissoncology.com 25
Any ideas? I tryied to disable also the filter but nothing changed....
Nicola Moresi
RE: SMTP Drop connection - 2.Jan.2008 10:47:53 AM
MIDOOooo
first make sure to create computer object for exchaneg and publish it as a server to server publishing rule and publish SMTP from ISA to exchange and then use the wizard to publish exchange 2003.
http://www.microsoft.com/technet/isa/2006/deployment/exchange.mspx
this might help
Enterprise Support Engineer
Vodafone - Egypt
(in reply to Moresi)
RE: SMTP Drop connection - 3.Jan.2008 10:27:02 AM
Moresi
Hi Midoo,
thank you very much for your reply!
I tryied but nothing happened.
I find that I have the same problem with publishing DNS...
Strange, in the event log the firewall tells me that the port is already in use..
On the DNS server I have selected to bind only to the internal address... also on the SMTP...
Do I miss something?
Thank you very much!
(in reply to MIDOOooo)
RE: SMTP Drop connection - 3.Jan.2008 11:43:43 AM
MIDOOooo
try to use secure port or change port settings and use another port other than 25.
Vodafone - Egypt
RE: SMTP Drop connection - 7.Jan.2008 3:24:58 AM
Moresi
Tryed another port (9876) but same problem...
I have the same problem also on the 80, 53...
Maybe try to reinstall?
RE: SMTP Drop connection - 7.Jan.2008 7:57:34 AM
MIDOOooo
just install ISA to seperate desktop..it deosn't require much resources.
it will be much easier to make ISA on seperate machine.
Vodafone - Egypt
RE: SMTP Drop connection - 7.Jan.2008 8:40:17 AM
Moresi
Yes I know, it's better, but my clients doesn't have a free desktop...
And the strange thing is that with ISA2004 everything works well.
RE: SMTP Drop connection - 7.Jan.2008 2:50:54 PM
MIDOOooo
take care that the server you are publishing now is the local host itself (i.e. isa) so maybe to apply the rules and include local host also.
Vodafone - Egypt
