SMTP via FWC Problem
All Forums >> [ISA Server 2000 Firewall] >> Firewall Client >> SMTP via FWC Problem Page: [1]
SMTP via FWC Problem - 18.Jul.2002 12:10:00 PM
SanMan
Hi All...
Problem - internal clients cannot access external smtp servers using the FWC. Using SecureNAT this works fine. What could the problem be ?
LogFile
10.0.0.16 TheUserN telnet.exe:3:5.0 2002-07-18 10:07:20 TheISASRV1 - MailSRVIPAddi 25 - - - 25 TCP Connect 0 42 184
Protocol rules are enabled to allow external access to all users wanting to use SMTP outbound this does not work. WHY ???
SM
RE: SMTP via FWC Problem - 22.Jul.2002 2:18:00 AM
SanMan
Any ideas from anyone ???
(in reply to SanMan)
RE: SMTP via FWC Problem - 24.Jul.2002 6:51:00 AM
SanMan
So I guess that nobody know anything about the Firewall Client and setting up user authorisation.
RE: SMTP via FWC Problem - 24.Jul.2002 7:44:00 AM
SanMan
Now we are getting somewhere... I ran the Ethereal Proggie in order to find out what packets are being sent where details are as follows...
Client message: Hello
Server message: Hello Acknowledge
Server message: User Info Acknowledge
Client message: Resolve
Server message: Resolve Acknowlegde
Client message: Connect
Server message: Connect Acknowledge
Client message: User Info Acknowledge
Drilling down till the last comment before the error ...
MS Proxy Protocol
Client ID : 0x1587644
Version : 0x30100
Server ID : 0x37c11500
Server ack : 1
Sequence Number : 2
RWSP Signature : RWSP
Command : 0x400 (User Info Acknowledge)
Unhandled request command (report this, please)
Does anyone know why this happens ??? SPOUSEELE ???
Many Thanks
RE: SMTP via FWC Problem - 25.Jul.2002 12:19:00 AM
Hi SanMan,
you got my attention! [Big Grin]
It seems you have read my article about the FWC. Thanks! Don't bother about the 'Unhandled request command (report this, please)' in the Ethereal trace. It's a failure in the MS Proxy protocol decoder of Ethereal itself! [Razz]
In the Ethereal trace the RWSP sequence seems to be OK. After the 'Server message: Connect Acknowledge' do you see the client setting up a TCP connection? You should!
In the logfile, is the Result code (field sc-status) = 0? It's hard to tell because it seems you have not enable ISA to log all fields or you have not posted the whole line.
RE: SMTP via FWC Problem - 25.Jul.2002 10:38:00 PM
Hey guys,
Sounds like the external mail server is not responding. Run a NetMon on the external interface of the ISA Server.
Also, turn on Rule#1 and Rule#1 in the log files.
RE: SMTP via FWC Problem - 29.Jul.2002 1:17:00 AM
SanMan
Hi Tom and Stefaan,
Well I have the enabled full logging now and details are listed from the server -
10.100.100.100 SanMan01 telnet.exe:3:5.0 N 2002-07-28 22:47:40 fwsrv ISAServer1 - smtp.xtra.co.nz 203.96.92.131 - - - - - - GHBN - - - 0 - - Allow rule 5211 0
10.100.100.100 SanMan01 telnet.exe:3:5.0 N 2002-07-28 22:47:41 fwsrv ISAServer1 - - 203.96.92.131 25 - - - 25 TCP Connect - - - 0 - SMTP Access Users Allow rule 5211 81408
10.100.100.100 SanMan01 telnet.exe:3:5.0 N 2002-07-28 22:47:41 fwsrv ISAServer1 - - 203.96.92.131 25 40 - - 25 TCP Connect - - - 0 - SMTP Access Users Allow rule 5211 81408
When I disable the firewall client and connect to the same remote mail server this is done successfully... strange though that in the FWC logs the following is discovered -
10.100.100.100 - - N 2002-07-28 23:02:49 fwsrv ISAServer1 - - 203.96.92.131 25 40 - - 25 TCP Connect - - - 0 - SMTP Access Users Allow rule 5228 81546
The group SMTP Access Users is set to allow any request outbound... no security, but I have disabled my firewall client so why is it logged in the FWC logs ???
Here are the IP Log entries -
2002-07-28 23:19:07 203.96.92.131 10.100.200.200 Tcp 25 63312 PSH ACK ALLOWED 10.100.200.200 45 00 00 74 31 85 40 00 3d 06 77 93 cb 60 5c 83 ca 25 a2 62 00 19 f7 50 ea 0c 07 6a bc cf 59 b4 50 18 60 f4 5b b6 00 00
2002-07-28 23:19:07 10.100.200.200 203.96.92.131 Tcp 63312 25 ACK ALLOWED 10.100.200.200 45 00 00 28 44 a9 40 00 80 06 00 00 ca 25 a2 62 cb 60 5c 83 f7 50 00 19 bc cf 59 b4 ea 0c 07 b6 50 10 44 24 d7 93 00 00
Please contact me should you require any further details... many thanks
SanMan
RE: SMTP via FWC Problem - 29.Jul.2002 10:18:00 PM
Hi SanMan,
according to your logs, the SMTP connection is allowed and seems to succeed (result code = 0). Because you didn't show the close of the connection, I can't determine if there was effectively data exchanged.
BTW --- all Firewall and SecureNAT request are logged in the Firewall log! [Big Grin]
RE: SMTP via FWC Problem - 30.Jul.2002 1:05:00 AM
SanMan
Stefaan,
That all that the log shows, there is no end of connection... only those three entrys... what happens on the client screen is shown below :
H:\>telnet smtp.xtra.co.nz 25
Connecting To smtp.xtra.co.nz...Could not open a connection to host on port 25 :
Connect failed
Thats is... weird :/
Rgds
San
RE: SMTP via FWC Problem - 30.Jul.2002 4:50:00 AM
SanMan
OK it has been fixed... apparantly there seems to be a problem with the authentication mechanism. A package called Webfldrs was installed on the server and this could have modified the winmgmt and msinfo files which in turn caused UserEnv 1000 error in the application log. I applied to MS for a hofix and this resolved my problem, here is the KB article Q285192.
Many Thanks for all the ideas guys.
San
RE: SMTP via FWC Problem - 30.Jul.2002 1:09:00 PM
Hi SanMan,
good to hear you got it working and thanks for the follow up! [Smile]
RE: SMTP via FWC Problem - 31.Jul.2002 7:20:00 AM
SanMan
Hi All,
SP3 for Windows 2000 has been release and contains this fix... so if you apply it it should fix the problem... not too sure whether it will break anything else [Razz] But let me know if it does.
Rgds
San
