SPOOFING_PACKET_DROPPED from remote site in VPN to ISA Array
All Forums >> [ISA 2006 Firewall] >> VPN >> SPOOFING_PACKET_DROPPED from remote site in VPN to ISA Array Page: [1]
SPOOFING_PACKET_DROPPED from remote site in VPN to ISA... - 11.Jul.2007 5:27:30 PM
rGreg
I have 2 ISA 2006 Enterprise servers in an array in the main office.  (HQ1 and HQ2)
3 remote ISA 2006 Enterprise servers (Single server arrays) servers connect via L2TP/IPSEC VPNs.
ISA puts 2 VPN tunnels on one array server, and 1 on the other.
The tunnels are up fine, and I can get to all devices in the remote site.
I have 2 interesting problems.
#1 is annoying only - The HQ Array constantly alerts "ISA Server VPN Tunnel redistribution is recommended".  It seems it wants 1.5 connections on each member.
#2 is more serious.  Our ISA configuration server is on HQ1.  Any site that has its VPN tunnel connected to the array via HQ2 cannot access HQ1.  Pings follow the same pattern.  IF I ping from a remote site connected via HQ1 - it can ping HQ1 but not HQ2.  IF I ping from a remote site connected via HQ2 - it can ping HQ2 but now HQ1.  When any of these connections fail, the log shows a denied connection with a result code of "0xc0040014 FWX_E_FWE_SPOOFING_PACKET_DROPPED"  The source address of that dropped connection is an address from the VPN static pool.
We are using static address pools all around (required on multi-server arrays).  I am aware of http://support.microsoft.com/kb/917025 - but that doesn't seem to apply because the tunnels are fully up.  I am also aware I can turn off spoofing detection - but I really don't want to.
The HQ Array is made up of 2 servers - each with 3 physical interfaces - Inside/Outside/Intra-Array
Thanks All.
rGreg
RE: SPOOFING_PACKET_DROPPED from remote site in VPN to... - 11.Jul.2007 7:02:50 PM
johnny_mango
Hi, with regards to your spoofing problem, the most likely is that the range of addresses you put in the static pool is a subset of the addresses defined in the properties of the Internal Network.
As far as I am aware, you can put pretty much anything for the static pool, as long as it doesn´t overlap, for if it overlaps how can the ISA determine what is a VPN client and what is an internal client?
(in reply to rGreg)
RE: SPOOFING_PACKET_DROPPED from remote site in VPN to... - 11.Jul.2007 10:57:34 PM
rGreg
Thanks... But no dice - Isa does not allow you to define that type of overlap.
(in reply to johnny_mango)
