SQL DMZ
SQL DMZ - 15.May2001 6:56:00 PM
marcush
Hi, I have a tre homed setup. On my internal network i have an sql sever with a private range ip. On the perimeter network i have a WWW server with a public ip that vill make querys to the sql server in my internal network. Is that possible and how do i do it? Thanx in advance Marcus ------------------
RE: SQL DMZ - 16.May2001 1:28:00 PM
bobajob
Hi, You need to setup up a protocol def for port 1433 outbound from you local network (Configured as a secureNAT client) then you need to setup the MTS transactions this is a bit tricky see q250367 this explains how to restrict the port ranges for RPC and the DTS connections. Let me kow how you get on Cheers BOB
RE: SQL DMZ - 17.May2001 4:34:00 AM
Hi Marcus, There are two ways to do this: 1. Publish the SQL server ports required for the transaction with the Web Server 2. Better, create a VPN connection between the web server and the SQL server. HTH, Tom ------------------ Tom Shinder http://www.isaserver.org/shinder/ Get it Here!
RE: SQL DMZ - 22.May2001 1:13:00 PM
bobajob
quote: Originally posted by tshinder: Hi Marcus,There are two ways to do this: 1. Publish the SQL server ports required for the transaction with the Web Server 2. Better, create a VPN connection between the web server and the SQL server. HTH, Tom
Hi, Tom How would you create the VPN between the webserver and the SQL server ? cheers bob
RE: SQL DMZ - 23.May2001 8:04:00 PM
Hi Bob, Make the machine on the DMZ a VPN server and the machine on the internal network a VPN client. HTH, Tom ------------------ Tom Shinder http://www.isaserver.org/shinder/ Get It Here
RE: SQL DMZ - 30.May2001 9:45:00 PM
DeveloperX
quote: Originally posted by tshinder: Hi Bob,Make the machine on the DMZ a VPN server and the machine on the internal network a VPN client. HTH, Tom
Ok, I have your book right here, and on page 603 is has Enabling Communication between Perimeter Hosts and the Internal Network. I have followed the directions, but it does not work. I looked in the logs and the packets are being blocked. Is there a quick and easy way to do this, besides using VPN
RE: SQL DMZ - 8.Jun.2001 5:45:00 PM
DeveloperX
I am trying to get SQL on an internal interface to communicate with a web server in my DMZ. I created client address sets for the 3 segments of my network. I published the SQL server to the perimeter network using server publishing rules and address sets. The NIC card on the perimeter net has only one IP assigned at present. So I set the server publishing rule use that IP, and use the built in Microsoft SQL server definition for the incoming packets. I put a port sniffer on the Perimeter network, and I can see the packets making it to the interface, but they never get routed onto the internal network. I put a port sniffer on the internal network and observed that the packets never show up on the internal network. I checked the logs from ISA, the packets are not being blocked at the perimeter network NIC. What is the problem, I even tried packets filters to handle the outgoing SQL calls from the Web box. Also can the Web box on the perimeter network make the sql call to the actual ip's on the internal interface, or do I have to call the "Published ip on the perimeter network?" I am about to change to a point to point configuration. Thanks for any help you can be on this issue.
quote: Originally posted by tshinder: Hi X,What have you tried that did not work? Thanks! Tom
RE: SQL DMZ - 9.Jun.2001 3:52:00 AM
Hi Dev, What is the purpose of using the interface address for the DMZ in the rule? The rule should be using the IP address of the server on the DMZ and *not* the ISA Server interface that interfaces with the DMZ. HTH, Tom ------------------ Tom Shinder http://www.isaserver.org/shinder/ Get It Here
