SQL Publishing Problem
All Forums >> [ISA Server 2004 General ] >> Server Publishing >> SQL Publishing Problem Page: [1]
SQL Publishing Problem - 1.Sep.2005 10:42:00 AM
CrazyProf
All of the configurations are below
Please do not take care of the topology for security because we are on the starting point and doing test phase.
ADSL Modem (Connected to Internet "[Smile]" )
WAN IP...........................: 444.444.444.444
LAN IP...........................: 192.168.1.254
Port 1433 is forwarded to IP 192.168.1.1 (ISA 2004 Machine)
ISA Server 2004 (2 NICS):
Ethernet Adapter 1:
IP Address. . . . . . . . . . . . : 192.168.1.1
Default Gateway . . . . . . . . . : 192.168.1.254
DNS Servers . . . . . . . . . . . : 192.168.1.254
212.58.3.2
Ethernet Adapter 2:
IP Address. . . . . . . . . . . . : 10.0.0.1
SQL Server Configuration:
IP Address. . . . . . . . . . . . : 10.0.0.100
Default Gateway . . . . . . . . . : 10.0.0.1
ISA Firewall Client Installed
MS SQL Server Running and using default Port 1433
Also I have some computers out of control of ISA 2004 as in the 192.168.1.X Network. These computers are using 192.168.1.254 as default gateway.
Also there is only three rules for Firewall Policy
Last / Default Rule / Deny / (Bla bla)
2 / Internet / Allow / All Outbound Traffic / All Networks / All Networks / All Users
3 / SQL Publish / Allow / Microsoft SQL Server / All Networks / 10.0.0.100
So even if a request comes from outside from port 1433 ADSL modem forwards it to ISA server. There is no problem.
Also any computer on 192.168.1.X can request on port 1433 to the ISA Server
But then ISA server uses in both case 2nd Internet Rule instead of SQL Server Publishing.
As I monitor with a query the process this is the result.
Log Time: Time
Destination IP: 192.168.1.1
Destination Port: 1433
Protocol: Microsoft SQL (TCP)
Action: Initiated Connection
Rule: Internet "[Confused]" "[Confused]" "[Confused]"
Client IP: 192.168.1.200 (from my 192.168.1.Y Network)
Client Username:
Source Network: Internal
Destination Network: Local Host
Log Time: Time
Action: Closed Connection
Client Username:
I can not found where the problem is. I am expecting if any request comes to ISA 2004 on port 1433 it forwards this req. to my SQL Server and establishes a communication between the client and server. But it decides to use Internet Rule instead of SQL Server Publishing Rule. (I create SQL Server Publishing Rule by the Server Publishing Wizard)
So if anyone help me I would be thankful.
Best Regards
Ahmet Usta
RE: SQL Publishing Problem - 2.Sep.2005 4:29:00 AM
isawader
What's the IP range you included in the Internal Network definition?
You should only have 10.0.0.0 - 10.0.0.255 in it.
-Remove the firewall client from the SQL server.
[ September 02, 2005, 04:32 AM: Message edited by: ISAwader ]
(in reply to CrazyProf)
RE: SQL Publishing Problem - 2.Sep.2005 9:03:00 AM
iraq it
When you publish SQL Server in ISA so who can access the server from outside?
Is publishing SQL server other solution for VPN?
RE: SQL Publishing Problem - 2.Sep.2005 10:22:00 AM
isawader
Al-Taee,
If I understand you correctly, I think you like to know how to safely publish your SQL server to the internet, right?
I would highly recommend that you don't publish your SQL server. If you have to, use VPN.
RE: SQL Publishing Problem - 3.Sep.2005 2:59:00 AM
iraq it
Hi ISAWader,
Iam workig on:
http://www.microsoft.com/technet/prodtechnol/sql/2000/maintain/proxy.mspx
and hope there is not security risk with it.
