SSH, Telnet, RDP, and FTP blocking
All Forums >> [ISA 2006 Firewall] >> General >> SSH, Telnet, RDP, and FTP blocking Page: [1]
SSH, Telnet, RDP, and FTP blocking - 7.Mar.2007 12:04:45 PM
drumtrav
I work in a helpdesk environment, we only want to use ISA to block internet access to certain websites and block all internet to certain users.  That is setup and working fine.
However, The helpdesk users often use FTP, Telnet, SSH, and RDP to connect to customer's site and work.  I have create access rules to allow these protocols.  However, they are not working.
My questions are.
1.  IS there a way to setup the ISA (2006) to not worry about the listed protocols.  (bypass and let end to end communcations)
2.  If not, how should these be setup besides the obivious rules I have in place.
In my error logs I am getting the following for ssh and telnet:
0x0 ERROR_SUCCES
then after 60 sec
0xc0040038 FWX_E_TCP_NO_SERVER_REPLY
We use putty for ssh programs, and a program called PRocomm for telnet connections.  Putty does have a tab for proxy settings, procomm does not.  We use IE for FTP connections
RE: SSH, Telnet, RDP, and FTP blocking - 9.Apr.2007 11:18:04 AM
How many NICs in your ISA Firewall?
(in reply to drumtrav)
RE: SSH, Telnet, RDP, and FTP blocking - 9.Apr.2007 11:42:15 AM
drumtrav
Sorry I meant to update this.
I resolved my issue with the best pratices analyzer.  We have one NIC and after I ran the single ended NIC wizard and changed some rules.  It works now.
RE: SSH, Telnet, RDP, and FTP blocking - 10.Apr.2007 10:41:59 AM
That's the problem, you're running in "hork mode" which only supports HTTP and HTTPS. No other protocols are supported in "hork" or "broken" mode.
Get a second NIC in that ISA Firewall ASAP! Right now you're not secure.
RE: SSH, Telnet, RDP, and FTP blocking - 10.Apr.2007 11:02:18 AM
drumtrav
We are secure.  This is all behind our Cisco ASA appliance.  I am not using this as a true "firewall".  I'm only using this for a proxy to limit internet access to users.  I'm not interested in anything else it does.  It is working just fine.
RE: SSH, Telnet, RDP, and FTP blocking - 11.Apr.2007 12:41:39 PM
Check www.secunia.com and compare the bugs in the ASA compared to ISA. ISA is much more secure than an ASA and I personally don't consider the ASA to be secure until Cisco gets some better understanding of what's happening above layer 3.
