SSL & SharePoint - Will this scenario work?
SSL & SharePoint - Will this scenario work? - 23.Jul.2004 4:39:00 AM
heydonp
Hello,
At the moment, we are using SharePoint for various projects and have a number of subdomains that we need to manage. For each subdomain we use SSL and hence have a public IP for each instance.
As we have a limited number of public IPs in our company, I'm investigating the use of ISA to act as a single entry point, and then depending on which subdomain the client is requesting, redirect/tunnell to the appropriate virtual web server (this redirection doesn't need to be encrypted as we're within our DMZ at this point)
The intention is to consolidate the use of public IP's down to 1 if possible. We currently have a wildcard SSL certificate for our sites.
From what I've read, I understand that this setup will work with ISA. I'm hoping to get confirmation that this scenario is possible with ISA, before I start devoting too much more time & energy and finding out that this won't work at all.
Thanks, Peter
RE: SSL & SharePoint - Will this scenario work? - 24.Jul.2004 7:38:00 PM
Hi Peter,
It will definitely work. However, you should *always* perform SSL to SSL bridging. The remote user has an implicit agreement that there is a secure connection from end to end, and that implicit agreement is broken if the ISA firewall performs SSL to HTTP bridging. It doesn't matter how secure you think the DMZ is, if the information moves in the clear, someone can get to it pretty easily.
HTH, Tom
RE: SSL & SharePoint - Will this scenario work? - 28.Jul.2004 1:20:00 AM
Hi Peter,
No problem! Let us know if you have any questions or problems with the config.
Thanks! Tom
