SSL Client Cert Authentication - need lots of help
All Forums >> [ISA 2006 Publishing] >> Web Publishing >> SSL Client Cert Authentication - need lots of help Page: [1]
SSL Client Cert Authentication - need lots of help - 27.Nov.2006 5:01:16 PM
jayshaw91
That pretty much says it all.  I need a start-to-finish on what needs to happen for this go work.
We have an internal PKI and we'd like to use for the cert.  I know we need to get the entire cert chain installed on the client.  That's not the issue.
So the question directly relates to the ISA steps, I guess.  Also, what cert do we have the ISA server look for?  Can we use just one cert, or a unique cert per user?  Either method is acceptable.
Thanks.  It looks sorta easy in the few tabs there are to look at, but I need some advice.
RE: SSL Client Cert Authentication - need lots of help - 28.Nov.2006 10:44:48 AM
Hi Jay,
I did a two part series on KCD and User Certificate authentication on this site.
Check it out.
(in reply to jayshaw91)
