SSL Denied Connection Errors
SSL Denied Connection Errors - 1.Apr.2005 3:07:00 PM
fe_colin
We're setting up a new ISA 2004 server to provide a secure SSL connection into our webmail (iNotes) server. I've created the server publishing rule, set up the listener and taken care of the certificates - that seems to be ok. When I access the URL, the browser asks if I want to accept the cert (which is fine), then displays the login screen with encryption enabled. When I try to log in, I get a warning about being redirected to a connection that is not secure (I'm using SSL to HTTP bridging). I click OK, and the process stalls.
Now here's the good bit - if I leave the browser for long enough, it comes up with a standard "Page cannot be displayed" error ("The gateway has lost the connection with the Web site you are trying to access."). If I click back (to the login screen) then forward again, it opens up my mailbox and everything works fine.
The ISA monitoring shows a lot of Initiated/Closed/Denied connections, originating from the client and going to the ISA server, port 443/HTTPS. There is no rule mentioned. I'm presuming that they are the reason for the odd timeout thing, but I can't eliminate them. I've tried adding various rules for ports 80/443 incoming and outgoing but to no avail.
I'd be grateful if anyone can make any suggestions where I'm going wrong.
RE: SSL Denied Connection Errors - 3.Apr.2005 6:17:00 PM
Hi FE,
Is it working for SSL to SSL bridging?
Thanks! Tom
RE: SSL Denied Connection Errors - 4.Apr.2005 12:37:00 PM
fe_colin
I was trying to avoid the extra complexity involved with that as we don't think it's necessary in our situation. However, I'll maybe give it a shot and see if it makes any difference.
Thanks for your response.
Colin
RE: SSL Denied Connection Errors - 11.Apr.2005 12:53:00 PM
fe_colin
Well it now appears to be working, but I'm afraid I don't know what triggered the change. I did clean up all the static routes on the server and redefined the internal network, which may have helped. Nothing involved was on anything undefined though.
I had presumed that the "redirected to a connection that is not secure" browser message was a by-product of the ssl to http bridging, but that has also disappeared despite the bridging mode being the same.
Thanks anyway Tom for your input.
