SSL Guidence/Installation
All Forums >> [ISA Server 2004 Firewall] >> DMZ >> SSL Guidence/Installation Page: [1]
SSL Guidence/Installation - 23.Jan.2006 8:18:38 PM
ranweb
I am asking for any assistance in the understanding of SSL Installation/Management for a public website that is in the DMZ or perimeter network.
Currently, my configuring for the website is Internet--ISA--Perimeter (Website).  I'm needing to install a SSL for the entire site (www.company.com) which is on a web server on the perimeter network.  The site is up and running; however, I need the SSL for a few application to work.
I'm about to work with Verisign; however, I'm wondering about the CSR generation for the SSL Certificate... do I generate it from the webserver in the DMZ or do I generate it from the ISA Server???
Ranweb
RE: SSL Guidence/Installation - 24.Jan.2006 4:44:56 AM
Hi Ran,
If you're going to use SSL to SSL bridging, you can run it from ISA firewall, then you can fry up your own certificate to bind to the published Web site.
I think i wrote an article for TechProGuild on how to do this, but I don't know if they put it up yet.
(in reply to ranweb)
RE: SSL Guidence/Installation - 24.Jan.2006 4:50:00 AM
Hi Ranweb,
Nope, I didn't write it for them, I wrote it for ISAserver.org, however it has not yet been published. Write to me and I'll send you the article series.
RE: SSL Guidence/Installation - 26.Jan.2006 5:18:01 PM
ranweb
Tom,Thanks for the information.  These are great articles.  I do have a comment/question.  The article primarly focuses on OWA and the use of Private Certs within the LAN.  In your example, you use a CA in the same LAN that the OWA server is in.  In my scenario, I am trying to perform this same process; however, its with a Web Site and the Web site is in the DMZ, not in the LAN.  Do I need to put CA on a box running in the DMZ?  The two computers in the DMZ consit of an IIS and a SQL server which is in a workgroup, they don't belong to a domain.
  • Can I use the scenario in your article and apply it to my environment?
  • Can I use a CA in a work group environment, what are the pro's and con's?
    • Would I be able to use an internal LAN CA for the IIS in the DMZ?
Randy
