SSL OWA works ok externally but not internally
SSL OWA works ok externally but not internally - 19.Mar.2004 12:57:00 PM
awj
I have OWA setup on a public address using SSL with my own certificate authority eg webmail.acme.com. This works fine when you connect externally but it you try to connect internally you get
<TD width The page cannot be displayed
In the browser, any ideas on what is causing this and how to fix it?
RE: SSL OWA works ok externally but not internally - 19.Mar.2004 12:59:00 PM
awj
Sorry should also have said my rule allows the SSL traffic to come from anywhere to the Exchange server and i have SSL bridging ie it is encrypted inside and outside the Firewall.
RE: SSL OWA works ok externally but not internally - 21.Mar.2004 5:35:00 PM
Hi Al,
Internal clients should not access internal servers through the firewall. Instead, configure the Web proxy clients with the autconfig script (or just have them autodetect and enable autodiscovery on the firewall) and then configure the firewall to instruct the Web Proxy clients to use Direct Access for internal domains and addresses.
You'll find these config options in the Properties of the Internal network.
HTH, Tom
RE: SSL OWA works ok externally but not internally - 22.Mar.2004 11:30:00 AM
adelprete
Tom, is there a specific reason to why you say that internal clients should not use the proxy?
I've a split dns infrastructure and I've published OWA via SSL via public IP also for internal clients and everything's perfect.
RE: SSL OWA works ok externally but not internally - 23.Mar.2004 4:03:00 AM
Hi Alessandro,
Looping back through the firewall puts unnessary strain on the firewall resources and isn't required to access Internal resources.
HTH, Tom
RE: SSL OWA works ok externally but not internally - 23.Mar.2004 10:36:00 AM
awj
Ok i made sure that Internet Explorer is set to bypass the proxy for all addresses starting 192.168 (which would include my internal exchange server)
I also added a host A record to my internal DNS for the name of the outlookwebmail.acmecorp.com and if i tracert it internally it goes to the correct server (i also now sometimes get asked for windows authentication but never see the Outlook form i get from externally). Then i still get the same message as before, any ideas?
RE: SSL OWA works ok externally but not internally - 23.Mar.2004 12:13:00 PM
Hi Al,
The Web Proxy clients need to be configured to use the autoconfiguration script. You can manually config the browser, set this up via Group Policy, or the easiest why is to configure the client to autodiscover (which is the browser's default setting).
You'll need a wpad entry in DNS/DHCP, and enable autodiscovery publishing on the firewall. I use this at every site and it always works a treat!
HTH, Tom
