SSL port 4443
All Forums >> [ISA Server 2004 Cache] >> General >> SSL port 4443 Page: [1]
SSL port 4443 - 15.Apr.2005 10:54:00 AM
grootj
Hello,
I'm trying to connect to a site (http://www.azr3.trias.nl)over port 4443
(SSL)but the ISA server (ISA 2000 on win2000)blocked the site. (The page can not displayed).How must I configure ISA 2000 that the request leaves at the new port 4443 instead of 443?
Met vriendelijke groet,
Johan de Groot
systeembeheerder
tel: 0341-278226
email : j.degroot@philadelphia.nl
RE: SSL port 4443 - 15.Apr.2005 3:29:00 PM
Create a New Protocol Definition.
Open Firewall Policy,
click "ToolBox" on the right
select Protocols
Expand Web
click New -> Protocol
Type "Alternate SSL" and click Next
Use TCP as the protocol type, Direction Outbound, Port Range 4443 to 4443 and click OK.
Don't use a secondary connection, click Next
Click Finish
Edit your Allow Rule and add the new protocol to the Protocols tab.
HTH
(in reply to grootj)
RE: SSL port 4443 - 15.Apr.2005 10:09:00 PM
Hi johan,
if you want HTTPS access to an unstandard port number, check out http://support.microsoft.com/default.aspx?scid=kb;EN-US;283284 . I suggest you grab the script 'ISA Server 200x tunnel port tool for non-standard Web Proxy port connections' from http://www.isatools.org/ and run it on the ISA server.
RE: SSL port 4443 - 18.Apr.2005 10:32:00 AM
grootj
Hi Stefaan,
Thanx, I have execute the VBScript from http://support.microsoft.com/default.aspx?scid=kb;EN-US;283284 and now i have another error in internet explorer : The page cannot be displayed
There is a problem with the page you are trying to reach and it . Do you know how i can fix this ?
Johan de Groot
systeembeheerder
tel: 0341-278226
RE: SSL port 4443 - 18.Apr.2005 8:58:00 PM
Hi Johan,
what are the ISA logs telling you?
BTW --- you are talking about ISA 2000 and this is an ISA 2004 forum! [Confused]
