SecureId protection for Sharepoint using ISA2006
SecureId protection for Sharepoint using ISA2006 - 14.Aug.2006 10:26:01 PM
jwf1776
I’m trying to setup a proof of concept demo of SecureId protection for Sharepoint using ISA2006 for Authentication. I’ve setup SecureID AuthMangr on another computer and assigned a token to a test user “Jeremy”. I changed the ISA2006 system policy to allow SecureID communication to the SecureID server. I downloaded the isa2006 sdtest util, installed it, and can verify authentication of the user Jeremy with the key fob OTP. I setup a firewall rule using the sharepoint wizard to publish companyweb.domain.local, forward actual host header, apply to all requests, redirect to port 80, Weblistener is on a dedicated external IP, listens on port 443. When web listener authentication is set to “Active Directory” authentication I can authenticate fine. When I set web listener to “SecureID” with “require all users to auth” “use rsa 5.0 name locking” and use separate user passcode pages” I get this: “106: The Web server is busy. Try again later.” So it appears that the publishing is configured correctly but something with SecureID isn’t correct. I haven’t been able to find reference to this ISA error by googling. Can you assist me in troubleshooting this issue?
RE: SecureId protection for Sharepoint using ISA2006 - 15.Aug.2006 6:08:51 AM
Hi Jeremy, Try using SSL to SSL bridging, since that's the only secure configuration. Might work, might now -- but at least you haven't horked your security config with the dreaded SSL to HTTP bridging nightmare scenario. HTH, Tom
RE: SecureId protection for Sharepoint using ISA2006 - 18.Aug.2006 9:00:50 PM
isaserver@moon.demon.nl
Hi, did you copy the sdconf.rec file to the %systemrot%/system32 folder? Did you create an RSA Agent host in ace server? Clear node secret on that host and activate rsa log monitor, see what error message you get. Regards
RE: SecureId protection for Sharepoint using ISA2006 - 5.Oct.2006 11:14:04 PM
jayshaw91
I'm having issues with this, also. The problem is, me and the RSA dudes don't know what we're doing. - We added the RSA agent host for my ISA server - He created a *.rec file and that is now copied to the folder named below The problem is, I don't know how to configure the web listener properly. On the listener, I go to Authentication, click Advanced, go to RSA SecurID tab and I don't have a clue what to do with the Name Locking checkbox (what's that for?), and how to Manage Domain Secret. For the Domain Secret, I pointed to the *.rec file we copied to the system32 folder and when it asks for a password it won't take what I ender. Also, it seems to want to find a *.sdi file. Um, yeah. Help a clueless man out!
