SecureNAT and Remote Desktop
SecureNAT and Remote Desktop - 8.Dec.2005 9:54:53 PM
apolloth
Since upgrading to ISA 2004 I have had a nagging little issue with Remote Desktop. Our network has many subnets, some at remote sites, some on the same logical segment as the ISA. When I create a server for web publishing and I make it a SNAT client, I am no longer able to remotely access that server from anywhere except machines on the same logical segment. After changing the gateway address back, I can access it no problem. I didn't have this issue with ISA 2000, so I am wondering if there is a rule required to allow traffic since all the SNAT clients packets are routed to the ISA 2004 box. All subnets are correctly included in the Internal Networks listing. It is currently causing headaches becasue once I publish sites on that box as an SNAT client, remote administration becomes a headache. What am I missing? Any help is appreciated Apolloth
RE: SecureNAT and Remote Desktop - 8.Dec.2005 11:59:36 PM
apolloth
Thanks spouseele for responding so quickly. After installing ISA, I had the common "ISA server detected routes through adapter Local Area Connection..." and I did read the above articles and found that my routing table had been updated while the Networks address list had not. I no longer have that problem, but I still do have the issue aforementioned. ISA sits on a segment spanning 172.16.112.1 to 172.16.119.255. This is the logical segment most of our servers sit on, including the box needing to be published. Most of our web developers work from a site on the LAN at 172.16.4.1-172.16.7.255. The addresses are not as important as the fact that no other subnet can remote the machine once it becomes an SNAT client. If the Internal Network list on ISA04 has the subnets properly listed for my internal network, what am I missing? Since both segments are considered internal, I wouldn't expect to need anything like a network rule to govern the connection, correct? Thanks for any help Apolloth
