Hello Tom, What you said about the application filter makes sense, now that you said it and I begin to understand how it works. Oh, and I will visiting the bookstore today to pickup your book. If it's helpfulness is anything like this board, and I totally expect it to be, then it will be money well spent. </suckingupoff>  Okay, I don't know if this helps, but here is a copy of a "solution" document AMS (program vendor) provided us. I was going to list exactly what I have done in ISA, but it looks like pcAnywhere has died on my ISA machine, so I can't get in. Damn. Oh, here is that document: quote: PROBLEM: AFW ONLINE: Server Browser Error:... trying to Login to AfW OnlineSUMMARY: AFW ONLINE: Cannot connect to AfW Online server AMS PRODUCT: AfW Online INFORMATION: When the user clicks on Login to AfW Online, they receive the error: "Server Browser Error: Either network is not functional or you must configure address under server location." The agency may have an internal firewall for their network that is blocking the Citrix ICA Client packets. CONFIGURATION: Microsoft Internet Explorer v4.01 or higher is required. PROCEDURE: Per the Citrix document, "Ports Required to be Open for Connectivity Through Firewalls and Routers", if an internal firewall (or proxy server) exists, the following list of TCP/IP and UDP ports must be opened on the firewall and routers for ICA packets to pass through: * TCP/IP port 1494 (inbound) * UDP port 1604 (inbound and outbound) * Outbound (from the server to the client) ports 1023 and above (a maximum of 65535) for both TCP/IP & UDP.
WARNING: AMS does not recommend setting up direct access to the AfW Online IP address since it is subject to change without notification. ADDITIONAL INFORMATION: The above information was published on the Citrix website. For additional information, refer to the Citrix website at www.citrix.com. Navigate to the Support site and search the Knowledge base using the word "firewall".
WORKAROUNDS: None. As long as the Citrix ICA client is being used, these ports are required to be opened.
As usual...thanks for any help!
------------------ -Billy
