SecureNat and Web Proxy
SecureNat and Web Proxy - 19.Sep.2007 1:49:54 PM
Ryanjkeen
Hi, Before I go out of my tiny little mind and miss the Man U match tonight I hope some one can help with with this little issue. Setup - 3 Servers (win3k3 - 1 sql, 1 exch, 1 ISA 2006) 100 XP Pro pc's IE7, Cisco Pix. ISA running in single Nic mode, customer only wants to use ISA as proxy. IE is setup with following server4a 8080 for proxy, and Autodetect settings the Issue is 80% of the users can still get out on the internet and by pass the http filters. I watched the filter screen and saw that the client was using securenat; the other 20% that show in the logs use Web Proxy. and they get blocked from going to banned sites. Can some one please tell me how to block securenat clients? Thanks Ry
RE: SecureNat and Web Proxy - 19.Sep.2007 4:39:51 PM
Hi, You are using your ISA Server with a single NIC, what we call a hork mode ! So if you clients are able to change their default gateway and their proxy setting, then they would easily bypass your ISA Server ! If you were using ISA Server as a backend Firewall with Two NICs, then you would have more control on your users.
RE: SecureNat and Web Proxy - 19.Sep.2007 7:13:07 PM
Ryanjkeen
No they cant change, Gateway or Proxy - its well screwed down! I have removed the default gateway from everyones pc now - still no joy. Ry
RE: SecureNat and Web Proxy - 19.Sep.2007 11:21:20 PM
ferrix
Something seems wrong about your description.. The concept of "secure nat" mode only applies to hosts that use ISA as the default gateway, which is not your case because you're running single NIC and ISA's not in the exit path of your LAN. With a single NIC the only way for ISA to inspect HTTP traffic is when browsers willingly connect to the ISA :8080 port. Hitting ISA as the default gateway shouldn't even be possible in this configuration. Anyway how you keep your proxy policy "screwed down" on your web clients is really not anything to do with ISA at all. With your setup, it seems like the easiest way to force using ISA is to lock your pix down so only ISA can originate outbound HTTP connections. That way anyone who doesn't use the right proxy settings will be unable to get out at all.
RE: SecureNat and Web Proxy - 28.Sep.2007 10:22:43 AM
Ryanjkeen
Hi Everyone, Ok I have really banged my head now.. Isaserver 2003 sp2 R2 Single Nic 192.168.1.56 Pix 192.168.1.251 All systems have IE proxy server set and users not allowed to change the settings. Pix is set to only allow out bound access from the ISA server. When the below settingare in place PC2 can access the Web fine, the filtering works. PC1 cant access the Web PC1 Win Xp, (firewall disable) IP 192.168.1.122 Sub 255.255.255.0 Gateway 192.168.1.56 (outlook 2007 complains like hell when no ip in gateway) DNS 192.168.1.7, 192.168.1.52, 192.168.1.56 PC2 Win Xp, (firewall disable) IP 192.168.1.129 Sub 255.255.255.0 Gateway 192.168.1.56 (outlook 2007 complains like hell when no ip in gateway) DNS 192.168.1.7, 192.168.1.52, 192.168.1.56 --------------------------------------------------------------------------------- Isaserver 2003 sp2 R2 Single Nic 192.168.1.56 Pix 192.168.1.251 All systems have IE proxy server set and users not allowed to change the settings. Pix is set to ALLOW all PC's out bound When the below setting are in place - PC1 can access the Web fine, the filtering does NOT works. PC2 can access the Web fine, the filtering works. PC1 Win Xp, (firewall disable) IP 192.168.1.122 Sub 255.255.255.0 Gateway 192.168.1.251 (outlook 2007 complains like hell when no ip in gateway) DNS 192.168.1.7, 192.168.1.52, 192.168.1.56 PC2 Win Xp, (firewall disable) IP 192.168.1.129 Sub 255.255.255.0 Gateway 192.168.1.56 or 192.168.1.251(outlook 2007 complains like hell when no ip in gateway) DNS 192.168.1.7, 192.168.1.52, 192.168.1.56 Any Ideas?
< Message edited by Ryanjkeen -- 28.Sep.2007 10:39:50 AM >
RE: SecureNat and Web Proxy - 28.Sep.2007 10:29:31 AM
ferrix
These settings are identical.
RE: SecureNat and Web Proxy - 28.Sep.2007 10:41:07 AM
Ryanjkeen
edited - Sorry, my mind is not 100% today
RE: SecureNat and Web Proxy - 28.Sep.2007 10:46:11 AM
ferrix
I'm pretty sure you can't use SecureNAT mode on a single NIC ISA server. I don't know why it works at all in your testing; I would advise to stop trying to do it. PIX should only allow http/s outbound from ISA server as in config 1. Clients should have PIX as gateway as in config 2. There is clearly something wrong on PC 1 that is not shown via the things you are posting. I recommend wiresharking your traffic to see what's going on, and correlate it with what's being seen in your ISA and pix logs.
RE: SecureNat and Web Proxy - 28.Sep.2007 10:58:38 AM
Ryanjkeen
I do I stop securenat from working?, Thanks for helping with this!!, i am trying to think what else could be on the pc thats causeing this - The config for all the PC's will be once this is sorted- Isaserver 2003 sp2 R2 Single Nic 192.168.1.56 Pix 192.168.1.251 All systems have IE proxy server set and users not allowed to change the settings. Pix is set to only allow out bound access from the ISA server. PC1 Win Xp, (firewall disable) IP 192.168.1.122 Sub 255.255.255.0 Gateway 192.168.1.251 DNS 192.168.1.7, 192.168.1.52, 192.168.1.56
RE: SecureNat and Web Proxy - 28.Sep.2007 11:26:27 AM
ferrix
You stop it by the pix configuration set not to allow all PCs to use http/s. That way if the user uses say a different browser or manages to change their proxy settings, they will still not succeed at bypassing isa. I have no further suggestions about your PC1 issues beyond all my ones above.
RE: SecureNat and Web Proxy - 29.Sep.2007 5:26:46 AM
Ryanjkeen
Ok thanks for your help anyway, i have just reloaed windows on pc1 and it now uses isa - must be something with in XP that doing it. only another 123 to go! Ry
