SecureNat for wireless DMZ
All Forums >> [ISA 2006 Firewall] >> DMZ >> SecureNat for wireless DMZ Page: [1]
SecureNat for wireless DMZ - 26.Jul.2011 10:07:36 PM
pawan525
Hi
I am using ISA 2006 as a 3 leg perimeter.I am using DMZ network for wireless clients only.
DMZ interface of ISA is connected to linksys router, which is also DHCP server for wireless clients and i am using dns splits for wireless clients as shown in following article
http://www.isaserver.org/tutorials/2004wirelessdmzpart1.html
here is my configuration
NIC configuration of DMZ
ip - 192.168.1.1
mask- 255.255.255.0
lynksys router's config
ip - 192.168.1.2
mask - 255.255.255.0
DHCP range - 192.168.1.100 - 192.168.1.150
DNS server - 192.168.1.1
my clients gets the following config after connection
ip - 192.168.1.104 (any ip from range)
Gateway - 192.168.1.2 (router's ip)
DNS - 192.168.1.1
with this config, nslookup works fine but the can't browse internet untill i provide web proxy which is 192.168.1.1 with port 8080
my ISA rule is allow all outbound traffic from dmz to external for all users
But why it is not working as secureNat? what am i doing wrong ?
RE: SecureNat for wireless DMZ - 27.Jul.2011 2:11:50 PM
paulo.oliveira
the article is using a wireless AP (Access Point) and you are using a wireless router.
You must create a network between ISA DMZ NIC and wireless router WAN port, like 172.16.0.0/30
Paulo Oliveira.
(in reply to pawan525)
RE: SecureNat for wireless DMZ - 27.Jul.2011 9:30:53 PM
pawan525
Thanx Paulo,
plz be more specific. do u mean i should create a network between ISA DMZ NIC and linksys router by inserting cable into WAN internet port rather than lan port of router. do i need to change any other configuration? dmz nic and router would be on same network like mentioned in that article or not?
i need some more details plz.
(in reply to paulo.oliveira)
RE: SecureNat for wireless DMZ - 28.Jul.2011 1:01:34 AM
pawan525
I might not explained it properly. i am using linksys E1000 router which is directly connected to ISA DMZ NIC via router's LAN port. so i think it is working as Access Point. so if i using it as a WAP because it is also on the same network on which DMZ NIC is. so in this case what could be the reason for SecureNat issue.
Any suggestion?
RE: SecureNat for wireless DMZ - 28.Jul.2011 10:20:05 AM
paulo.oliveira
wireless "routers" are NAT devices. You must be sure it can be configured as AP. It is not just because you connected ISA DMZ NIC on the LAN port of wireless router that it is working as an AP.
Paulo Oliveira.
RE: SecureNat for wireless DMZ - 28.Jul.2011 5:25:24 PM
pawan525
Ok, Suppose i want to use it as a router. In that case DMZ NIC will be connected on WAN port. What else i need to change? Router's network?
Plz comments abt my ip settings. Can this router fulfill the purpose of AP like shown in the article?
RE: SecureNat for wireless DMZ - 29.Jul.2011 10:00:51 AM
paulo.oliveira
you must configure a network between wan wireless router interface and ISA DMZ NIC, you can use 172.16.0.1/30. Then the LAN network of your wireless router could be 192.168.1.0/24
Paulo Oliveira.
RE: SecureNat for wireless DMZ - 1.Aug.2011 8:37:21 AM
pawan525
Thanks Paulo
Its working now. It was grt help. I really appreciate ur help. Thanks once again.
RE: SecureNat for wireless DMZ - 1.Aug.2011 8:51:09 AM
paulo.oliveira
thanks! Glad it worked!
Paulo Oliveira.
