SecureNat https ssl doesn't work
SecureNat https ssl doesn't work - 28.Dec.2005 6:01:27 PM
celledge
I have remote clinets that come into my network NAT'd on 10.155.0.100 with my ISA server as the final route. They are all SecureNat clients. They can access http pages fine, but none can't access https pages. If I make them Web Proxy clients they work fine, but I can't do this as it creates a problem from some of my applications. I have read through the board and haven't found a solution. I have confirmed that the HTTP filter is NOT turned on in the https protocol. Am I missing something?
RE: SecureNat https ssl doesn't work - 28.Dec.2005 10:13:32 PM
celledge
I have no connection limits defined. This was working a week ago. I can't fingure out what changed. Your book should be arriving this afternoon, so maybe it will help.
RE: SecureNat https ssl doesn't work - 29.Dec.2005 3:49:34 AM
celledge
I found the problem and it is a strange one. I had an IP address set configured originally for a single IP address - 10.155.0.100. I changed this last week to include more addresses - 10.100.0.0 through 10.155.255.255. That is what created my problem. I changed this back to a single address and created a new subnet set for the 10.100.0.0/16 subnet. That corrected my problem and covers exactly what I need. Could the problem be that I changed the address set? Perhaps I should have deleted it and created a new one. Or, did I try to cover too many addresses? Either way, I have it done right now and it works. Maybe this will be helpful for others.. By the way Tom, I received your book today and it is a good reference. Chris
RE: SecureNat https ssl doesn't work - 29.Dec.2005 1:54:17 PM
smelethil
anybody help me to block yahoo messenger
RE: SecureNat https ssl doesn't work - 9.Jan.2006 3:24:58 AM
96ghia
I have a similar issue, but slightly different. I have a JIRA installation that sits on :8000 internally, and a Web Publisher that publishes the /jira site on SSL, which then passes the item onto :8000 on the internal interface. For naming and link reasons, I want internal machines inside the ISA firewall, to access the site using the external link. I find that when the client acts as a web proxy client, that the linkworks perfectly. However, if the Web Proxy item is turned off in IE, that the http link works, (returns the "use SSL/HTTPS" to get to this page message) but when trying to access it via https, (whcih works for all external machines, and the local host) it fails, (404 message, like it can't even see the machine) opinions?
RE: SecureNat https ssl doesn't work - 9.Jan.2006 7:26:32 PM
Hi 96, That's exactly how it should work. It can't work with SecureNAT clients because those aren't proxied connections. You should always use Direct Access and split DNS for internal clients accessing internal resources. Check out the Direct Access articles on this site to see how it works. HTH, Tom
