Secure NAT client, how to bypass proxy with digest auth enabled ?
Secure NAT client, how to bypass proxy with digest auth... - 8.Nov.2005 4:58:00 AM
maurorazzetti
Hi guys,
i've dismiss ISA 2000 and a new ISA 2004 server is running. All LAN client are Secure NAT (most are Linux/Unix) and Firewall Client can't be installed.
Digest auth with Active Directory is enabled and works perfectly. All user are auth and logged.
I need for ONLY ONE user of LAN (linux) to bypass Auth and proxy settings to access http, https and ftp protocol on the web. At last, this client cannot be put into DMZ section.
How can i do ?
any help or idea is appreciated
Mauro
RE: Secure NAT client, how to bypass proxy with digest ... - 13.Nov.2005 7:43:13 PM
Hi Mauro, Create an Access Rule that allows the IP address of that host anonymous access to the protocol and site you want that host to access. Make sure to put this rule above all authenticated access rules. HTH, Tom
RE: Secure NAT client, how to bypass proxy with digest ... - 15.Nov.2005 5:17:13 PM
maurorazzetti
Tom , first of all, thanks for your support. auth for web browsing is defined on "internal" properties of "Networks". If "require all users to auth" is checked, this is for all. how can i do, to make this setting for all -1 users with access rules ?
RE: Secure NAT client, how to bypass proxy with digest ... - 15.Nov.2005 6:12:21 PM
LLigetfa
Instead of "require all users to auth", apply authentication on a per rule basis instead.
RE: Secure NAT client, how to bypass proxy with digest ... - 25.Jan.2006 11:07:01 AM
cheewei
Will this method work with basic authentication?
RE: Secure NAT client, how to bypass proxy with digest ... - 9.Feb.2006 3:12:11 PM
chico28
Ciao Mauro ho provato anche io con la digest auth ma mi sfugge qualcosa. Continua a chiedermi login e pwd.Uso l'enterprise edit. e sto lavorando con delle policy a livello di array non enterprise Con l'integrated funziona Hai un esempio Grazie Davide
