Secure web publishing with ISA in DMZ
All Forums >> [ISA 2006 Publishing] >> Web Publishing >> Secure web publishing with ISA in DMZ Page: [1]
Secure web publishing with ISA in DMZ - 19.Sep.2008 11:21:53 AM
greyhorsecorp
I have dilema that has to be solved.
I want  ISA 2006 Std. to be capable of publishing multiple secure web (https)  sites that are located in a LAN.
There is Sonicwall NSA 5000 series in front of ISA with Layer 3 firewall only. Swall is facing internet and ISA is behind it.
There is NAT-T between WAN and DMZ, and ROUTE relationship between DMZ (ISA) and internal LAN.
I have talked to Sonicwall and they said that from Sonicwall side is enough to setup 1-2-1 NAT from WAN to DMZ (external interface of ISA) and since ISA is publishing those secure sites, it should forward https requests to secure web servers internally.
In discussion with consultant, he says that this is not possible,since ISA's web listener can not have multiple https (with different public certificate names) tunnels established on only one "listening IP-the one that is facing internal interface of the NAT device in front of it, in this case Sonicwall.
In order for this to work, he basically recommends to have FE Firewall (Sonicwall) with multiple public IPs binded to one public interace, but such an option doesn't exist even though Swall has Sonic Enhanced OS with latest firmware. What he said basically is that in that case, every single https tunnel would be assigned specific Public IP that is in a back end binded to specific private ip. So, if we have 3 https tunnels, he says that we should have 3 public IPs and 3 private IPs on ISA, so that the tunnels can work.
I was thinking that having Swall open WAN to DMZ firewall rule (Layer 3 firewall) for all incoming https traffic to ISA would be enough. So, if let's say 3 simultanious secure web sites requests come in from the internet, they would hit publically available WAN ip (single IP, since all 3 secure web sites are registered with the same public IP)  of the Swall. Swall as layer 3 firewall doesn't care about the number of https requests, but just let it forwarded to external interface of ISA (that is btw in private IP address range, since it is in NAT-T relationship with Sonicwall-as mentioned earlier).
ISA intercepts those 3 requests on it's front end IP address, inspects them and forward them to internal secure web servers, after which 3 https tunnels are established between web servers and clients.
My question is: Is ISA 2006 capable of handlig (publishing) 3 simultanious https tunnels through it's own web listener, by having all 3 tunnes coming in to ISA on one IP address (it's front end NIC that is facing Swall)  and forwarded to secure web servers in a LAN through it's second NIC in a back end?
RE: Secure web publishing with ISA in DMZ - 24.Sep.2008 9:17:12 AM
You will need three public addresses to make this work. A single IP address is supported by a single certificate. You can use a single Web Listener, but that Web Listener must bind the certificates to different IP addresses.
The best solution would be to remove the Swall, bind three addresses to the external interface of the ISA firewall, and be done with it
(in reply to greyhorsecorp)
RE: Secure web publishing with ISA in DMZ - 24.Sep.2008 10:07:11 AM
greyhorsecorp
Thank you Tom.
I have already solved the first part of a puzzle; have setup Sonicwall properly with NAT-T and have setup two multiple Public IPs for 2 internally published https web sites and it works with no problems.
All internal web sites (that are published) are sitting on the same box with 2 different (internal) IPs.
Now, the problem came in when I installed ISA 2006 Std. First of all, I want to have full HTTPS tunnel from client on the WAN up to internal Secure web server. If I use https between WAN client and ISA, and back end on port 80, all is OK. So, I am aware that I have to use Bridging option on ISA. I have also added lmhost entries for thos two internal servers on ISA.
I have installed local certificates on each web server. I have also created listeners for those web servers on ISA and they have publicly recognized certificates with web sites public names.
To make long story short, listeners are listening at regual 443 port (each) and in a back end, when ISA needs to forward traffic for specific server in LAN, I have set one https tunnels to be on 443, the other on port 444. Doesn't work. I have also setup back end tunels to 443 both and still the same.
I have also setup on both web server to force 128 bit encryption and require Secure SSL.
I am getting various errors when I try to access them from outside:
Error 500, network logon failed and so on.
What I am doing wrong here???
RE: Secure web publishing with ISA in DMZ - 29.Sep.2008 9:01:39 AM
Are you using SSL to SSL bridging on the firewall?
And you use a split DNS from end to end?
RE: Secure web publishing with ISA in DMZ - 29.Sep.2008 9:26:25 AM
greyhorsecorp
I made it...woohoo...yes
FYI, this is what I did to make it work:
Since this is still lab I have used selfssl.exe and selfdiag.exe from MS as well as IIS 6 Metabase Explorer to create certificates. Since this utility initially had bug, as soon I created certificate for the first web site, I have exported it with private key and deleted it from the web site itself (from Personal and Truested Root Certification Authority) and then imported it back to web site from just exported one. Then I have with ssl created another cert for another web site and imported it in to second web site.
I have then imported both certificates with priv keys on ISA and bound each cert to each listener for every single web site. So, each listener has the same cert name as the associated web site - that is imortant as you said in one of your articles and that was one of the things why it didn't work.
I have then set Bridging tab to have back end communication ISA->WEB servers on ports 81/444 and 82/445 respectively.
At that point, both web sites started working from WAN just fine. All requests come on port 80 or 443 ( I've set redirection from 80->443 for incoming requests) listener listens for web1 or web2 with public name, if matches found forwards it through bridging settings setup previously on port 444 and/or 445 for web1 or web2 and web sites respond to requests and HTTPS is fully established between client on the WAN and web published web site that is sitting internally.
I hope this might be useful to other as well.
Case closed.
Thank you Tom.
grey
RE: Secure web publishing with ISA in DMZ - 29.Sep.2008 9:41:05 AM
greyhorsecorp
I have solved the mistery. All is working perfect.
Thanks Tom.
P.S.
I've just typed the whole process to explain what I did to make it working and after hitting OK to send my reply, got SQL error-all what I typed was gone-web site and SQL didn't like each other this morning.
RE: Secure web publishing with ISA in DMZ - 29.Sep.2008 9:48:55 AM
greyhorsecorp
What...it showed up...COOL.
Grey
RE: Secure web publishing with ISA in DMZ - 30.Sep.2008 8:35:25 AM
Hi Grey,
GREAT! Good to hear you got it working and thanks for the follow up.
