Send out traffic with a specific IP?
Send out traffic with a specific IP? - 12.Aug.2005 6:22:00 PM
gquitugua
This is basically the problem I'm having. I want to be able to "meet" my pix rule of any originating traffic from ip address "xxx.xxx.xxx.21". Problem is all traffic leaving the ISA server is leaving tagged with IP of xxx.xxx.xxx.20 which is the ISA's dmz address. Is there a way to configure ISA so any traffic passed via a rule will pass as .21 traffic as opposed to the default .20?
Any help or suggestions would be appreciated. Sorry if the image is huge...in a rush >.<
GQ
RE: Send out traffic with a specific IP? - 15.Aug.2005 7:42:00 AM
Hi GC,
If you are using private addresses on the DMZ between the PIX device and the ISA firewall, then I believe I have figured out how you can do this.
RE: Send out traffic with a specific IP? - 15.Aug.2005 11:27:00 AM
gquitugua
Yes Tom,
We are using private addressing in the DMZ. A collegue suggested all we have to do is tell ISA that all outbound smtp traffic leaving ISA to the PIX, tag the traffic with the IP address .21 but I'm by no means an expert with ISA and I don't see how you can do that. If you've figured a way around this issue, I'm most definitely interested in what you've found.
GQ
RE: Send out traffic with a specific IP? - 18.Aug.2005 10:26:00 AM
Hi GQ,
What you need to do is create an ISA firewall network representing the external address on the ISA firewall that you want the source IP address to be.
Then create a Network Rule setting the route relationship between the SMTP server and that ISA firewall Network to Route.
HTH, Tom
RE: Send out traffic with a specific IP? - 18.Aug.2005 12:08:00 PM
gquitugua
Got it! Was wondering if you could comment on this setup:
I basically add a new network...let's call it "firewall". I gave it the address of the ".21" IP that was needed. (When I specify the IP...do I also need to specify the DMZ adapter in addition?). I then created a network rule for source: internal to "firewall" and set it to route.
Thanks again.
GQ
RE: Send out traffic with a specific IP? - 18.Aug.2005 3:49:00 PM
ClintD
Insert picture of Clint shaking his head...
quote: Then create a Network Rule setting the route relationship between the SMTP server and that ISA firewall Network to Route.
I'm trying to wrap my head around how setting the relationship to Route makes the Source IP change. Obviously it works, but I just don't see how it works.
RE: Send out traffic with a specific IP? - 29.Aug.2006 2:26:19 PM
stinkyprimo
Hi, i too have a similar situation to this. I did what you suggested but it does not work..... and how does a route relationship alter the source IP address.... and also a route relationship will only allow the host to talk to the host / network in the route relationship, so how is it supposed to to the outside firewall. Regards and i hope you can answer this... cheers
