Setting up a port to use SSL
All Forums >> [ISA Server 2004 General ] >> General >> Setting up a port to use SSL Page: [1]
Setting up a port to use SSL - 26.May2004 6:51:00 PM
gdsqx9
In ISA 2000, if I wanted to setup port 4445 to be used with HTTPS, I had to:
1. Create a protocol definition. It was setup with Port Number 4445, Protocol is TCP and it was outbound.
2. I also had to run a regedit entry to add port 4445 to the the registry .
In ISA 2004, I have created a protocol definition for 4445 - defined just like above. Now how do I apply it to HTTPS? I tried to run the script and it didn't work, but I didn't expect it to with this version is ISA.
Any ideas?
RE: Setting up a port to use SSL - 27.May2004 11:09:00 AM
zhangmeibo
hi , gdsqx9
In Isa server 2004 , if you allow all outbound , you needn't define a protocol for this port ,it can work properly , I using it this time.
but for only allow this protocol , I think you need define a protocol,you can define port number 4445 and direction is outbound .At last , I think isa 2004 stored configuration is different to isa 2000 .
(in reply to gdsqx9)
RE: Setting up a port to use SSL - 27.May2004 1:45:00 PM
gdsqx9
Thanks for the reply. I would like to know how you are doing it, I added the protocol definition and it is not working. I defined the protocol definition using port 4445, but how do I get ISA2004 to change the port from 443 on HTTPS to use port 4445?
RE: Setting up a port to use SSL - 27.May2004 8:30:00 PM
Bunshaw
It looks like you're trying to get SSL Tunneling to work, I had the same issue a few weeks ago. Here's a link to the thread:
http://forums.isaserver.org/ultimatebb.cgi?ubb=get_topic;f=24;t=000055
And here's a link Tom provided for some new SSL scripts that Jim H. wrote:
http://www.msfirewall.org/isa2k4_ssl_tpr.zip
RE: Setting up a port to use SSL - 28.May2004 4:13:00 PM
gdsqx9
Thanks that did the trick.
