SharePoint 2007 and Kerberos Constrained Delegation authentication?
All Forums >> [ISA 2006 Publishing] >> SharePoint Publishing >> SharePoint 2007 and Kerberos Constrained Delegation authentication? Page: [1]
SharePoint 2007 and Kerberos Constrained Delegation aut... - 7.Dec.2007 5:52:21 AM
mlindqvist
Hi!
I really would like to use the Kerberos Constrained Delegation feature (KCD) to authenticate external users to be able to use a SQL Server 2005 Analysis Filter webpart that we've configured. I've setup the SPN's and delegated the ComputerAccounts necessary as well as the ServiceAccounts needed and everything works internally.
The SharePoint publishing rule works fine as well coming from internet via NTLM, but as soon as one is trying to use the Analysis Filter web part, authentication fails.
If we change the Authentication level in the Publishing Rule from NTLM to KCD I only get "
Error Code: 403 Forbidden. The server denied the specified Uniform Resource Locator" in the browser.
The eventviewer on the ISA also shows "Description: ISA Server failed to delegate credentials using Kerberos constrained delegation to the Web site published by the rule OWA Access. Check that the SPN: http/<SERVER> configured in ISA Server matches the SPN in Active Directory."
But the SPN's are there!? I've also changed the SPN on the Auth Delegation tab to the internal FQDN (instead of the external FQDN which ISA defaults to).
I've read the excellent post here http://forums.isaserver.org/m_2002038062/mpage_1/key_/tm.htm#2002038062 as well as Stefaan Pouseele's other blogs (which I found by googling).
Has anyone done this with SharePoint? All I can find on the internet is just biased towards Outlook.
Any help much appreciated!
Cheers - Mikael
< Message edited by mlindqvist -- 7.Dec.2007 5:53:43 AM >
RE: SharePoint 2007 and Kerberos Constrained Delegation... - 25.Sep.2008 2:34:15 PM
icroyal
Did you ever fix this?  We're having the same exact issue.
(in reply to mlindqvist)
RE: SharePoint 2007 and Kerberos Constrained Delegation... - 8.Oct.2008 10:02:58 PM
joseph.a.paradi
The only thing that I might suggest is checking the identity on the app pool that the Sharepoint site is using.  With KCD, I am pretty sure that the SPN needs to be defined on the app pool ID if the app pool is not running as Network Service.
(in reply to icroyal)
RE: SharePoint 2007 and Kerberos Constrained Delegation... - 21.Oct.2008 6:35:59 AM
frobnitzz
http://forums.isaserver.org/m_2002068683/mpage_2/key_/tm.htm#2002072997
check my post, I've had great fun with KCD and MOSS.
(in reply to joseph.a.paradi)
