Silly ICMP doesn't work
All Forums >> [ISA Server 2000 Firewall] >> General >> Silly ICMP doesn't work Page: [1]
Silly ICMP doesn't work - 30.Jul.2003 9:05:00 PM
Popeyediceclay
You guys make it sound sooo easy. I have IP routing enabled, I have the gateway set on my client, the ICMP filters are set, and firewall client is installed (but I've tried all the different configurations). Can't ping or tracert beyond the ISA, when i try, it resolves the name to an IP but gets "request timed out", NOT "destination host unreachable." I cant even ping the upstream Netopia router. The ISA server can ping outside no problem. Also, when the firewall service is down, my workstation is able to ping outside and resolve. Am I doing something wrong here?
I guess I should also add that when I try to publish a server, it errors saying I don't have an external NIC, which is simply not true, sounds like a fluke. The only other error I'm getting is that I lost the ability to log packets somehow.
Thanks in advance, any help is greatly appreciated. Im running low on hair...
RE: Silly ICMP doesn't work - 30.Jul.2003 9:10:00 PM
Hi Popey,
check out your basic ISA server configuration. Use Jim's excellent article http://www.isaserver.org/tutorials/Configuring_ISA_Server_Interface_Settings.html as baseline. Also, check out the LAT on ISA server. The LAT should only contain your *internal* IP range, nothing more, nothing less.
(in reply to Popeyediceclay)
RE: Silly ICMP doesn't work - 30.Jul.2003 10:54:00 PM
Popeyediceclay
WOW, nothing feels better than lookin stupid. I guess the "construct LAT using w2k routing table" option is bad, eh? It also fixed my problem with the "missing" external NIC. I read an article about DNS zone transfers from my internal DNS to my ISP's DNS but I can't b/c mine says it's a root server. Is that the zone that is a "." ? Can I delete this?
Thanks for your advice, you saved my butt!
RE: Silly ICMP doesn't work - 30.Jul.2003 11:51:00 PM
Hi Popey,
OK, so far so good! [Smile]
The wizard is not bad, but you have to be very carefully in using it, especially when the ISA external interface is assigned a private IP address. So, the advice is to always check the LAT manually because it is a very critical table for ISA server. [Big Grin]
If you have an internal DNS server, don't specify an ISP DNS server on any adapter of the ISA server. Just the internal DNS server on the internal interface and make sure the internal adapter is listed first in the adapter order as explained in Jim's article.
Next, perform the following configuration steps:
1) configure the internal DNS server as a SecureNAT client. That means his default gateway should point to the ISA internal interface.
2) enable forwarders on your internal DNS server and specify there your ISP DNS servers. Also, make sure you check the ôDo not use recursionö box. If you can't enable the forwarders, delete the root zone "." and they will become available.
3) create on ISA a client address set containing your internal DNS server.
4) create on ISA a *seperate* protocol rule allowing the protocols DNS Query (UDP port 53 send/receive) *and* DNS Zone Transfer (TCP port 53 outbound) and apply it to the above created client address set.
5) create on ISA a *seperate* site&content rule allowing access to any destination or better to a destination set containing your ISP DNS servers, and apply it to the above created client address set.
Now, thoroughly test the DNS name resolving with the command nslookup. All should work well. Last but not least, never touch the DNS protocol and site&content rule again. You should now have a very stable DNS infrastructure.
RE: Silly ICMP doesn't work - 31.Jul.2003 4:37:00 PM
Popeyediceclay
Thanks alot man, you've single handedly cleared up all my headaches. I have the DNS setup exactly how you told me, but the ISA is not able to browse now. Everything else works fine. I have the adapter order correct, and it can ping anything, any ideas?
Thanks a million
RE: Silly ICMP doesn't work - 31.Jul.2003 4:39:00 PM
Popeyediceclay
Actually, it does work when I specify the browser proxy settings to point to itself, I guess that's how it should work
RE: Silly ICMP doesn't work - 31.Jul.2003 7:00:00 PM
Popeyediceclay
Welllll, now it doesn't work for some reason. It did work for about an hour, then stopped. I could only make it work again by adding the DNS IP's in ISA's external NIC. Do I need to add anything else in my internal DNS server, like zone transfers or add a name server?
RE: Silly ICMP doesn't work - 31.Jul.2003 7:59:00 PM
Hi Popey,
what does not work anymore? [Confused]
The internal DNS server should only have your ISP forwarders defined in order to resolve external FQDN's. So, without specifying the DNS IP's in ISA's external NIC, you should be able to do on ISA a nslookup of any external FQDN. It's very critical you test that extensively.
As a general rule, to give applications on ISA outbound access, you need to create IP packet filters. However there is one exception to this rule. Make IE on ISA itself a web proxy client by using the ISA internal IP address TCP port 8080 as proxy settings.
[ July 31, 2003, 08:00 PM: Message edited by: spouseele ]
RE: Silly ICMP doesn't work - 1.Aug.2003 4:59:00 PM
Popeyediceclay
Sorry for the confusion, after reviewing the logs I found that the DNS server was getting denied when it tried to go out (can't install the f/w client b/c it's a DC). I fixed the problem and now all is well, thanks for everything! Has anyone else tried to install a f/w client on a DC? It will stop me from accessing my AD when I do.
RE: Silly ICMP doesn't work - 1.Aug.2003 9:02:00 PM
Hi Popey,
in my opinion, the Firewall client is designed for workstations, not servers! My standard practice is to configure workstations as Web Proxy, Firewall and SecureNAT clients. The servers are configured as Web Proxy and SecureNAT clients only.
Therefore, in the posted guidelines for a stable DNS infrastucture, I explicitely state that the DNS server should be configured as a SecureNAT client and that you use client address sets on ISA for authentication.
RE: Silly ICMP doesn't work - 1.Aug.2003 9:41:00 PM
Popeyediceclay
works like a charm, thanks a million!
RE: Silly ICMP doesn't work - 1.Aug.2003 9:45:00 PM
Hi Popey,
glad to hear you got it working and thanks for the follow up! [Smile]
RE: Silly ICMP doesn't work - 4.Aug.2003 2:03:00 AM
dpeters
spouseele, can you explain why you need to do these three steps ?
RE: Silly ICMP doesn't work - 4.Aug.2003 3:19:00 PM
Hi dpeters,
very good questions! [Smile]
In my opinion, you should make the rules as specific as possible to avoid anonymous rules (any request). Because the Firewall client is designed for workstations, not servers, my standard practice is to configure workstations as Web Proxy, Firewall and SecureNAT clients. The servers are configured as Web Proxy and SecureNAT clients only. So, to avoid anonymous rule, you should authenticate the DNS server by IP address (client address set). That should pose no problem because servers should always have static IP's.
I wrote "Last but not least, never touch the DNS protocol and site&content rule again". Too often I see people playing with the protocol and site&control rules in order to get some policy working, and breaking by that the very critical DNS rules. Therefore I highly recommend to use *seperate* rules for the critical services such as DNS and Mail.
RE: Silly ICMP doesn't work - 5.Aug.2003 12:54:00 AM
dpeters
So those three steps are to "authenticate" the DNS server ? Why do you need to do that ?
RE: Silly ICMP doesn't work - 5.Aug.2003 8:36:00 PM
Hi dpeters,
yes and no! [Big Grin]
The goal of the *seperate* protocol and site&content rules is to protect yourself from breaking the critical services, such as DNS and Mail, when implementing a user/group based outbound access policy.
Now, you can only succesfully implement a user/group based outbound access policy if you have NO anonymous rules. An anonymous rule is a rule which applies to any request. Therefore your only option is to authenticate SecureNAT clients by using client address sets.
